GM Borla exhaust
Very easy! You may want to cut the OEM exhaust in half to make it easier to remove. Don't tighten everything up until it's all installed and adjusted.
Got off work at 5pm tonight and began the install, was done at 6:15. I didn't even lift the truck, just used my creeper. I cut the stock muffler pipe just after the muffler using a dremmel with cutting wheel. The exhaust came right out. Install was super easy. I do have one minor issue that I don't know how to solve. It seems right after the cat, the first pipe is resting on the frame. My system seems aligned, but it is indeed resting on the frame right at the expanding section just after the cat.
U have to bend up the bracket right at the crossmember. Either heat it up or uninstall it. Mine did the same thing.
Thank you, going to try this today by uninstalling and swinging my 5# hammer
It took 10 minutes to unbolt, remove the pipe, bend the bracket with my hammer and re-install. rumble at 1000 - 1100 rpm is gone. Thank you, this fix was very easy!
I'm glad this got brought up. With my Gibson there is a sporadic slight vibration/drone sound between gear shifts that I couldn't figure out. It doesn't happen all the time but is mildly annoying when its there. I checked and sure enough, the pipe is resting on the first cross member of the frame also. Will have to adjust mine also.
Thanks guys!
Any HP gain on the GM Borla or the Gibson upgrade?
I have the GMC 2015i 2500 6.0 Gasser SLT
Sierra Boy
I haven't had it dyno'd but seems to breathe better with CAI and exhaust, maybe a little more power. Gibson has dyno sheets on website showing around 20 hp for my 6.2l.
Thanks for the info...hope it sounds better!
Sierra Boy
Thanks guys!
Just a trick I figured out, I put a jack under the muffler to raise it a bit before I re-tightened all the bolts. Good luck, the fix works!
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
