i just bought a 2015 2500 and im wondering how to disable the DRLs. i did it on my 2012 by taking out 2 fuses. i dont see those fuses there. anyone do this on the new ones yet?
I wanted to do the same thing, but alas, they did away with the two fuse gig I had done in the past also. But, I have conditioned myself to reach over and turn the knob to the left and disable the DRL's when I start the pickup. Message comes up on the DIC saying daytime running lights disabled and you dismiss that message. I park the pickup in the garage and can tell that they are turned off. Also, when the wife is driving and coming to pick me up from my semi truck, I can tell they are off if she remembered to do the left turn thing when she started it up or any time enroute. Still seeking a more permanent solution, but this one has me somewhat satisfied.
Some wonder why anyone would even want to disable the DRL's. But those folks never go hunting or dealing with livestock on a farm or ranch.
Edited by Cowpie
yeah,that kinda stinks. I just don't like em on except for bad weather etc. being a mechanic for many years I get tired of changing burned out bulbs and melted plugs and wiring in the headlamp assemblies. that's why I always disabled them on my cars. maybe at some point someone will chime in with a fix for us. thanks
Start the truck, turn the headlight knob a click to the left to turn off DRL's, push and hold traction control to turn off traction control and stabilitrac and good to go.
I opened up the switch, removed the return spring, put switch back together and all set. Switch stays in the off position now.
ok,thanks for all the help. ill try it,i did see the other posts about this as well.
That's an interesting idea. Thanks! I will have to take a look at that.
im going to try this myself as well. thanks
Can't you just pull all fuses found on the fuse box? That usually does the trick.
No fuses on 2015. They figured out we were pulling them and hard wired DRL's.
  • Haha 1
We have a harness that will do it for you if you like tested it yesterday works fine, and we mad it move the DRL to the fog lights like it needs to be.
Edited by 2SSRS
How can we order this harness?
at the web site gen5diy.com sen an e-mail to sales@
  • 8 months later...
Some vehicles the DRLs are the hi-beams. Of all the vehicles that have their DRLs as headlights, about 95% use their hi-beams. Would love to switch my DRLs from lo to hi.
    1981dustin
    1981dustin
  • Who's Online   3 Members, 0 Anonymous, 1,425 Guests (See full list)
