My LED Headlights w/working DRL's!!
  • Replies 79
Wow I may have to try these..
So definitely better than Silver Star Ultras?
Do these light up more distance than halogens?
Any updates
Everything still works great! No flickering or any issues, DRL's work great during the day and at night they produce great light!!!
Yes, WAY better than Silver Star lights!
Yes, the beam does go further than the halogens. They don't scatter the light like HID's do, they produce a nice beam and provide a very clean light.
I wonder if there would be any clearance issues with the Sierra projectors/housings? If it works out, looks like a great plug-n-play solution to all our light issues!
No, those are ONLY my low beams!
I was very surprised how bright they are!
Do you get flashed at night with the brightness in the reflector housings I'd like to get a set but I don't want to blind everyone else lol also did you get a set for the high beams?
I ordered the Opt7 kit for my Sierra off Amazon. Just got it today and found the base smaller than the OEM . The fitment chart said ok for my truck . Contacted Opt7 and am awaiting a reply. Unless I did something wrong I would hold off ordering from Amazon. I'll post the response when I get it. Not good at link stuff, the kit I ordered was the
Opt7 LED headlight bulbs w/arc-glass clear beam kit- H11(H8,H9)- 60w 7,000lm Crystal White 6k CREE
Sounds good man, keep us posted. Hoping this will be a solution to my Sierra projectors without doing a full HID conversion etc.
The search continues!
I honestly haven't driven that much at night lately, but the small amount that I have I haven't been flashed. However given how bright they are I wouldn't doubt that I do.
My H11 kit fit perfect, but I'm pretty sure the GMC trucks use a different size?
Not sure, I used opt7's fitment chart on Amazon and ordered the recommended kit. Either the wrong one was sent or they have to correct whats in the box. The base and tabs on the leds of the ones I got are too small in circumference, won't even reach the mount. Still waiting on reply from them. :dunno:
I thought Sierras are HIR-2 (9012LL) sized. Unless there is some cross compatibility with other sizes I am not aware of...
Yes they are, I assumed that they would cross as well after matching up on their compatablity chart on Amazon. There isn't a 9012 choice offered as far as I can tell. But If you ck on the Amazon listing, it still shows the kit I received as a fit for 2014 gmc sierra 1500...
I believe its amazon's fitment chart that Is wrong, they are not cross compatible, I'm sure they did send you H11 but that's not what you use.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
