My LED Headlights w/working DRL's!!
These pictures are just the headlights on?
Yes, low beam headlights only and non-projectors.
  • Replies 79
Here are some better pics of the OPT7 beam pattern.
About 10-15ft away from the wall
At a stop sign
Driving 44mph
That's really not a good cutoff in my opinion and is probably creating quite a bit of glare.
I haven't adjusted my lights yet, they are in the stock location with a leveling kit and 33" tires so they look higher than they should be.
I installed the Opt7 LED's on my 2014 Sierra, just to try them out, and the light output was horrible. I used a 9006 kit since they don't offer a 9012.
Opt7 was great about issuing a full refund though.
Yea, I think people are having problems with them in Projectors since they aren't really made for them.
Nando, have you had any issues with leaving the dust cap on? I just read the instructions and it says to leave them off or drill holes in them for cooling. They do look great and have better cutoff than my factory bulbs at stock height.
Thanks!
I haven't had any issues at all, I also live in AZ where the temps have been in the 113-115 range pretty steady lately. I also did a 300mi. round trip this weekend out in the desert and the temps got to 117 and still never had a problem, shinning bright still when I got home.
I lowered my lights 4 turns since that pic and they are a lot better now and seem even brighter when driving since they are not pointing up into the air.
A lot of people talk about how crappy of a cut off it is from the pic but the stock lights have an even worse cut off so I don't know what they are talking about, these are not projector housings.
Sweet, thanks for the info.
I'm also considering the 5202 fog bulbs just for similar color. I don't care about their output not being as high as other options.
I can't give any opinion on how they would look but if you are only concerned about the color then they should work great!
Hey, Nando! Thanks for all the info. I've been contemplating an LED swap on my 14 for a while. I've installed countless HID kits, but never LED. Are yours still working well? Any idea of the quality of Opt7 customer service? Also, could you post pics after your re-aim? Thanks!
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
