To be honest, I've always thought Recon's headlights look like some cheap stuff off of a chinese "tuning" magazine. All of them, for any vehicle. I would just stay stock and add Oracle halos, but if you really want aftermarket, I'd go with Anzo. Their designs are much less "cheap looking", IMHO.
i like anzo tail lights better but the headlights i dislike...ill most likely just stay stock and put some HID in them which i know nothing about really. would hate to spend 6-9 hundred dollars on aftermarket headlights and dislike the look
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
