HID vs. LED
Have a TRS HID kit at home waiting to be installed once I get off the rig, but I have been reading alot, and it seems there are alot of people that are liking the LED kits. SO, I can't decide if I should go with the HID's I have, or sell them, and get a LED kit. I need something that is going to be reliable, and but out better light from the stock Sierra projectors. Any input, personal experiences would be greatly appreciated.
I've gone through almost every option for lighting; in stock projector: OEM halogen, 55W HIDs, and 45W VLED LMZ LEDs; now I have an FXR 3.0 w/ 50W 4300K HIDs
I think we all know how incredible the OEM halogens are so I don't need to same much about them except for that the whole idea of a halogen projector on a $50K truck should've been scrapped.
55W 5000K HIDs from DDM tuning in stock projectors were great, worked well, but still didn't light up the sides of the roads as much as the HIDs and in the projector headlights on my 02 Yukon, so I wasn't happy but I was satisfied enough to keep them. Then one day my HIDs decided to cr@p out on me with perfect timing cause I was 15 minutes into a 2 hour road trip, so I was glad I had just put in some Rigid Ind DOT approved pods cause they got me the rest of the way.
07D3CAF9-4117-4BFE-A749-D96D2F398282_zps
I then placed an order for VLED LMZ LEDs, got them in, they are great lights as well, BUT, if you want to get the best width, then you don't get the best distance, and vice versa
I have a tinted windshield, 45% over stock 70% so I'm at about 32% VLT, so the best light possible is very important to me
A few weeks ago I opened my headlights and used the FXR adapter bracket from Fastheadlights to install an FXR projector, man is this an improvement! This is the projector that these trucks should've come with from the factory!
7CBB4252-EAF4-4486-844B-5E5129A5E99E_zps
Don't have a shot of the LMZs at the same place, but the FXR and 55W HIDs were taken with the truck in the same position but the headlight adjustment was a bit higher when I took the HID pic since it had never been adjusted after getting the level kit. I made adjustments when I got home after taking the pics.
The HIDs in stock projector vs FXR, is there a HUGE difference in light output? No. Is there a huge difference in how much better the light is dispersed, projected (useful light at distance), and overall better road clarity? YES. I have had my tinted windshield through all the options, halogen, HIDs, LED, and now FXRs, and until the FXRs I never felt comfortable driving without having both my headlights, and fog lights on. Now with the FXRs I hardly notice when I turn the fog lights on [emoji16] and I feel as though I can see the road clearly in any condition
To sum all this up, if you can, DO THE RETROFIT! You won't be sorry! I'm actually getting ready to do 2 sets of Sierra headlights, one I'm doing everything I've done to mine, and the other will be just a retrofit. Both are for local people who have seen my lights haha.
I don't believe in the output out of a LED inside of a projector, myself.
The LMZs are pretty impressive in the FXR projectors, far better than they are in the OEM projectors. Can't beat an HID but not far behind them IMO (only in the FXR projector)
I started with LEDs and changed them out the same day to HIDs after having issues with the LEDs not being plug n play and needing a capacitor in order for them to work properly.
I didn't feel comfortable with doing the retrofit as I'm not sure I'm handy enough for it, but from what Mike and everyone else I've heard say, the retrofit will give you the best light. I don't have a tinted windshield (yet) so i wasn't as worried about that aspect of it. So far I'm liking my HIDs. Much, much better than stock.
But anyway, to sum it up: if you're handy enough to tackle the retrofit I would go that route, if not, HIDs.
Sent from my iPhone 6+
Well, before the truck I had a 2004 BMW with stock Bi-Xenons, and I totally felt the downgrade when I turned on the stock halogens in the truck. Put LMZ 5000k bulbs in there, I'm a happy camper. Is it as good as the OEM BMW lights (albeit 10 year old ones)? No. But it's almost just as good, and with that I'm satisfied. Install was much simpler than that of an HID kid, and I quite like the "instant on/off" capacity of LED's.
On a sidenote though, I avoided HID kits because I've just always had bad luck with them. I had three cars with them before, and one went through 2 ballasts, the next one through 3 bulbs, and the third one actually had a ballast catch on fire. Luckily I had an extinguisher in the car.
LMZ will not do much good in projectors for the tests I have seen so far. Because the properties of them shooting left and right only, they make great fog lights.
LEDs should best be used in refractors, not reflectors. example would be the F150 2015 using LED in a big lens to distribute light, the diode has to be facing the direction of travel, not left to right or 360, these designes are to simulate halogen bulbs, but never good enough.
Stock Silverado housing with LED bulbs only, plug and play.... I know you have a Sierra but this is just to show you the light output from LED's.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 382 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
