Dietch Posted June 23, 2015 Posted June 23, 2015 I'm wondering what are the most common and most helpful gauges people get for their pillar I'm looking to get a 3 set on a duramax what would the best be other then boost like most helpful
ATMINF Posted June 27, 2015 Posted June 27, 2015 I have a scanguage and it can read all the info that the computer puts out thru the OBD 2 port, the scanguage displays 4 different things at a time and the four things can be changed around as you like. I normally have coolant temp, trans temp, Instant MPG, and air intake temp. My truck is a gasser, so it doesn't really answer your question, but I wanted you to know there are different options out there for gauges. Good luck!
doverarjim Posted June 28, 2015 Posted June 28, 2015 I really like my Edge Insight CTS I but I am going to go with the new bigger Insight here soon. I have not added the direct exhaust temp connection I am just using the one that comes from the Obd 2 port. Like have the warning buzzer for some things like tranny temp when you are not watching everything real close, also like being able to watch the soot grams so I know when a regen has started or finished.
kstruckcountry Posted June 28, 2015 Posted June 28, 2015 I really like my Edge Insight CTS I but I am going to go with the new bigger Insight here soon. I have not added the direct exhaust temp connection I am just using the one that comes from the Obd 2 port. Like have the warning buzzer for some things like tranny temp when you are not watching everything real close, also like being able to watch the soot grams so I know when a regen has started or finished. New bigger?? Tell me more!
Chevor Posted June 28, 2015 Posted June 28, 2015 The old Edge CTS could read up to 10 perimeters at once. They advertised 8 latest update/download made it 10. New CTS 2 I see can read up to 12 and has a larger screen.
