GMC latest to announce Apple Car Play and Android
John Goreham
6/23/2015
Today GMC became the newest of GM brands to announce it is adding Apple Car Play and Android Auto to 2016 models. Last week it was Cadillac's Cue system that was announced as being updated for 2016 to include the ability to interface with one's smart phone. About a month ago, it was Chevrolet.
Still, the news is great. The trend towards having our more frequently-replaced phones be the brain and the vehicle's dash a slave to the information is one we all like. If there is any disappointment with the new technology, it is that a USB port must be used to physically connect the phone to the vehicle. Since Bluetooth hit its stride, many of us have given up that cord. With wireless charging now appearing it seems we are taking one step forward and two steps back.
GMC says the Apple Car Play features will be ready by the launch of the 2016 models, but that Android is trailing by a few months.
I said that this was the direction we would see things go well over five years ago. It's about time we stop buying technology over and over again and have a way to reuse what we already own. All we need in our vehicles is a display screen and maybe a couple of custom apps that are vehicle specific. This garbage about having navigation on our phones AND in our vehicles has made no sense to me for a very long time.
On the down side, all of the US carriers pulled unlimited data plans away from us. Sprint and T-Mo have brought them back in some fashion or other, but you pay through the nose for data overages (or large allotment plans) with VZW and AT&T. And, with there being no apparent way for GM to leverage its sheer size to get VZW to come up with a more cost-friendly hotspot plan, this is what we're going to have to be careful of.
On the NAVI front, specifically, I'd love a Garmin-type app that would allow me to pre-fetch maps whie I'm at home on Wi-Fi and then not have to access the data connection for navigation use while in the car. And, no, I don't mind having to buy the larger capacity phone to make that happen (my current Garmin unit requires about 18G to store a complete North America database of info).
I don't care about having to hard-wire (USB port) connect the phone - that makes perfect sense. What I -don't- like about it is that my phone will always be charging now as a result. There needs to be a way to USB connect the device and NOT have it be in charging mode as a result so that we aren't causing premature wear on our device batteries.
Yes, I understand that prematurely charging a NiMH or Lithium Ion battery doesn't affect its ability to hold a full charge. But, those batteries are only good for about 1,000 charge cycles. And, every time you plug it in to charge, that counts as a charge cycle. I purposefully run the battery in my phone down to maximize the length of time (in days/months) that the bettery will perform well.
@ember1205, Garmin has very high quality apps both on iOS and Android. They allow pre-fetching maps, and more. And, if you are an average user, you'll end up replacing the phone before the battery is a problem anyway so why worry about that?
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
