On 9/23/2019 at 5:51 PM, Rich M said:
I have a 2016 Custom Silverado.   My radio control will not allow me to increase my radio volume.  It gets to about 35 them the volume actually starts to go down as I turn the volume up.   Anyone having this issue and if so are you aware of a solution to this?
I'm having the same issue with my 2017 Silverado custom. It's going to the dealership next week to have the recall fixed and are going to look at the radio as well. I'm hoping to get an answer as to why its happening. I will update with an answer if I get one. If you find out what is causing the problem with the volume please let me know.
My 2015 just last week started to change the radio station on its own. Pauses live radio, or just skips back a min or so in the broadcast. And when this happens the speedometer switches to the radio display. I have a video but am not sure how to post it.
Just had the issue with the volume going down all the way on its own. After reading all the posts here played with the steering wheel volume control by punching the buttons. That did the trick for me; something must have gotten stuck there.
I have the same exact problem on my '17 Sierra Elevation Edition.  Max volume seems to be around 35 or 40.  The volume decreases above 40.   Its annoying not being able to hear the radio if its raining or passing a semi on the interstate.
Sounds to me like you need your HMI updated to latest spec, pretty common, kind of annoying to do because it ties up the stall for a while programming.
Hope this helps
-Friendly neighborhood GM tech
Just had this problem with my 17 Silverado. The volume wasn’t working properly I would turn it up to 60 and it would actually turn the volume down. Very simple fix my fellow bow tie fans, unhook the negative on your battery and let it reset for about a minute or two then throw it back on it will reset the system. Good luck guys
  • 3 months later...
On 1/30/2019 at 11:07 AM, TRC said:
I have a 2015 Silverado I was driving down the road and my display with the MPH showing went from there to what was playing on my radio. I went back to the MPH and it went straight back to the radio station again. Then when I went to use the push button on the radio screen to change the channel it wouldn't change the station. I could do it manually with the knob and could change the volume with the knob. I really don't want to take it to the dealership to have them charge me an arm and a leg for something simple that I could do by myself. Does anybody have any suggestions.
  • 5 months later...
I was having problems with the volume control buttons and volume knob on my 2014 Yukon.  The manual and online were no help.  I went into the Auto Volume menu and tried the buttons and knob there and they worked.  When I backed out to a radio station they still worked.  May not continue, but the volume controls are working right now.
This happened to me last week, I have a 2015 2500 diesel, my truck had been sitting for two weeks, I started it and drove it only two minutes then rolled down the windows and listened to the radio.  After 1+ hours the radio went to max, I turned it down and within 5 minutes it did it again, at that point it wouldn't turn down any more so I just shut it off.  An hour later when I went to start the truck it turned over slow like the batteries were drained.  I had the batteries and alternator check out and all were good.  So I think in my case, the radio going to max volume is an indicator telling you the batteries are starting to drain to low.  I did drive the truck for several miles after this happened to charge the batteries back up and the radio has worked fine ever since.
On 2/5/2016 at 10:29 AM, Pats1 said:
I've been to my dealer multiple times for this issue and still no results!
Anything that's wrong with chevy trucks between 2014-19 is "normal"
Although I did get my screen replaced and has seamed to fix my issues ( not same as your issues) but mine would change stations, switch to gps on its own( sometimes 20-30 times in a 20 minutes drive)
Could be a bad screen?
  • 5 weeks later...
I had this exact issue pulled infotainment fuse on passenger side. Fuse was fine turned it around and this fixed the problem immediately.
Good luck guys #44 15 amp for me 2019 silverado ld
  • 8 months later...
I’m having the same issue came out the store radio kept going full blast read some comments about the steering wheel buttons if I turned it down with the knob and held the volume button on the steering wheel it would fight it self lol but stayed so while holding the down button on the steering wheel I pressed the up button at the same time and now it’s fine 🤷🏼‍♂️🤷🏼‍♂️🤷🏼‍♂️
    Fishboat
    Fishboat
  • Who's Online   4 Members, 0 Anonymous, 556 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
