Sierra Denali check engine light after oil change
I took my 15 Sierra Denali 5.3 into the dealer on thursday for its first oil change at 7k miles. Was driving it on Sat when I noticed the truck start jerking on idle and misfiring when I accelerate up a hill. Also noticed a loud ticking sound outside of the truck when its running. It sounds like it could be the fuel injector and I am planning on taking it in first thing on monday. Also, check engine light came on and flashing when i accelerate.
Anyone think that this could be related to the oil change? what kind of damage can an oil change do? Truck was running smooth and beautifully before my oil change!
In case you are not aware:
A solid CEL is indication that something needs checking, tend to in short order.
A flashing CEL is indication that you need to pull over and turn the vehicle off immediately as something is more drastically wrong.
Per the owners manual:
If the malfunction indicator lamp
comes on while the engine is
running, this indicates that the
OBD II system has detected a
problem and diagnosis and service
might be required.
Malfunctions often are indicated by
the system before any problem is
apparent. Being aware of the light
can prevent more serious damage
to the vehicle. This system also
assists the service technician in
correctly diagnosing any
malfunction.
This light comes on during a
malfunction in one of two ways:
Light Flashing: A misfire condition
has been detected. A misfire
increases vehicle emissions and
could damage the emission control
system on the vehicle. Diagnosis
and service might be required.
To prevent more serious damage to
the vehicle:
. Reduce vehicle speed.
. Avoid hard accelerations.
. Avoid steep uphill grades.
. If towing a trailer, reduce the
amount of cargo being hauled as
soon as it is possible.
If the light continues to flash, find a
safe place to stop and park the
vehicle. Turn the vehicle off, wait at
least 10 seconds, and restart the
engine. If the light is still flashing,
follow the previous steps and see
your dealer for service as soon as
possible.
Light On Steady: An emission
control system malfunction has
been detected on the vehicle.
Diagnosis and service might be
required.
The following may correct an
emission control system
malfunction:
. Check that the fuel cap is fully
installed. See Filling the Tank on
page 9-70. The diagnostic
system can determine if the fuel
cap has been left off or
improperly installed. A loose or
missing fuel cap allows fuel to
evaporate into the atmosphere.
A few driving trips with the cap
properly installed should turn the
light off.
. Check that good quality fuel is
used. Poor fuel quality causes
the engine not to run as
efficiently as designed and may
cause stalling after start-up,
stalling when the vehicle is
changed into gear, misfiring,
hesitation on acceleration,
or stumbling on acceleration.
These conditions might go away
once the engine is warmed up.
If one or more of these conditions
occurs, change the fuel brand used.
It may require at least one full tank
of the proper fuel to turn the light off.
See Fuel on page 9-67.
If none of the above have made the
light turn off, your dealer can check
the vehicle. The dealer has the
proper test equipment and
diagnostic tools to fix any
mechanical or electrical problems
that might have developed.
Thanks for the info. This pisses me off more that it could be a serious problem. I do not think that it's a coincidence that this happened right after I got my car back from the dealer from a routine oil change!
Other than not putting oil back in or leaving something loose so it all runs out, there is nothing one could do changing oil that would cause a misfire.
Misfire can be caused by a couple of things. First thing I would check is both end of the plug wires, GM had some issues on some of the early trucks. This is not to say the maybe the tech pulled one loose on accident.
Did you check the oil level?
I thought about doing that a couple hours ago and will check it when I get home tonight. The truck has an oil level gauge so i would think that that would have warned me
Exactly why I stay away from dealership service departments! They cause more damage than they do good. I would not be surprised if one of those "GM certified technicians" unplugged something or knocked something loose while attempting your oil change.
Last time I was at the dealership for a free oil change and 'complimentary' tire rotation (that I ended up paying for after the fact) they broke my right front sway bar end link with the lift, didn't replace my valve stem caps after checking tire pressures, and broke a lug stud!
For the most part, they are clueless. They rely on the service books sent to them from GM and if your issue isn't exactly the same as in their little book, or not in the books at all, they tell you it's either normal or they could not duplicate the issue. There are some good ones but they are hard to find. Do yourself a favor and change your own oil, you'll better off.
Sent from my crappy iPhone 6
using Tapatalk
Last week, my truck exhibited the exact same conditions as wthomas86's truck. They diagnosed it as a bad #3 fuel injector. Dealer replaced it and now the truck runs fine, but it came home with a nice chip in the paint on the front fender that I am not too happy about.
Could the ticking be unpressurized lifters? That could be due to low oil level. I don't know if there is an oil-pressurized timing chain tensioner in these engines, but that's another possibility.
Took the truck to the dealer today after work. they haven't had a chance to look at it since it was the end of the day. took a rental and expecting a call tomorrow
Really? Depending on application for a 2014 Silverado , There up to 1000 trouble codes, 30+ programmable modules and 5 different networks. Not to mention dozens of sensors and all of the newer mechanical systems. And this truck is tame by Volt, ELR, CTS-V, Corvette standards. Yea, there are some Techs that probably shouldn't be fixing vehicles, But there are a lot of good ones. There are also a lot of do-it -yourselfers that should never be allowed to lift a hood. And for the record, our "little books" went away about 10 years ago. One more thing, lets not confuse "oil changers" with technicians.
Im glad someone understands. the dealership tech bashing on this site is crazy. I for one am a ASE and GM master certified tech and take great pride in what I do for a living.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
