DRL mounted to grill/ small
i dont know where i seen this but it was here...cant find it anymore...it was like small leds/ orange mounted to someones grill like the ford raptor has it....anyoone know how i can set this up? or where i can purchase them? i want to do something different...more costume look!
I believe you are talking about member Osmeac (think that's his username). He's got a thread with everything he used and did
9E325049-E01A-4B84-91A8-B074354263DB_zps
I did mine. ill try and find the link to the LEDs I used. I believe they are just 3/4" marker leds for a trailer. I have some in the rear aswell.
yeah more pics please! really interested on where u wired and how u did it! pics of the rear to please! thanks!
Very simple. Tied all 3 positive and all 3 negative wires together. Grounded the negatives to a grounding point on the backside of the radiator support. And tied the positives To a fused 4 pin relay that get signal from the ignition fuse.
Yup ^^ it's what I did except that I mounted my lights behind the honeycomb after creating templates out of plastic sheet.
Easy day ...
LOL No clue what you said there! on how to power it! i usually just tap into my 12v battery for stuff can u help me a bit more on where i can tap into? i kinda want them to like turn on when my truck is on and turn off auto when its off...just like lights....no switch....
Then just tap into the headlights bro. Since the headlights are DRLs, they'll function exactly how you described. Since T-tap with a quick connector will do the trick.
yep you can do that. I just wired mine to a relay since I was tapping into the ignition for power. I didn't want to increase the load on that. Then the power from the relay to the LEDs is fused so that way If anything shorts out I wont have to sacrifice a relay lol
ok so just tap into the DRL's ...umm say i get 3 or 4 lights? just put the positives together to combine, then just use that and tap into the DRL? say right side wire light? thats fine ? and then just ground the negative to where ever?.......and does anyone recommend a good splicing item?
Correct. If you're going to do it that way, make sure you double check your wiring cause if one of them is on wrong, none of them will work.
And use this to tap into the DRLs...
thank you so much!
