Suspension Upgrade
Hey, Just looking for some recommendations. I am debating on upgrading my front suspension to a 3/4 ton and looking at getting a ranch hand heavy duty front bumper for my truck. Looking to see if anyone out there has done an upgrade like this and what they had to do. Bare minimum looked like upgrading torsion bars, shocks, and springs. Is this even worth it without upgrading to a 3/4 ton silverado all together. Currently looking at doing this because I don't have the money to get a new truck but looking at other options for making this work. Ranch hand has a light weight 200lb front bumper but it looks flimsy compared to their heavier duty models but, as expected, they are heavier. If anyone else knows anything about these or has any expert advice, please let me know. I am looking at having this truck for years to come still so any help is appreciated. Thank you for your time.
No way to do it.
Your best option is throwing on leveling struts (Bilstein 5100 or similar), throw on the bumper and go. The bumper on my 2006 weighs no more than 200 pounds and is plenty strong for deer and similar. Any stronger, and it'll bend the frame anyways (like it should).
The 1500 utilitizes a strut suspension and 2500 has torsion bars. Completely different frame and mounting
Tyler,
What's the job you don't think the current suspension is up for? If you just want added load capability, think about some rear air bags, E rated tires, Helwig swaybars, some bigger front brakes and maybe some Bilstein shocks suggested above. The issue with all of this is that it costs money. Lots of it. If your truck isn't up for the task you need it for, it is probably cheaper in the long run to get the 2500-3500.
In order to replicate a 3/4 ton suspension, it'd require extensive cutting and welding on your frame to put all the different pieces from the crossmember to the A-arms and torsion bars. It'd be a mod that would gain you little in real load capability and make it ride much worse than you can get from the 1500 suspension. So, no, it's not worth attempting, IMO.
As the others have said, you can't really switch over to a 3/4 ton suspension. However, you can greatly improve your front suspension's ability to handle the extra weight. ICON, Fox and King coilovers all use standard race springs which come in any rate you want. I'm sure all of those companies have had plenty of customers who wanted something stiffer than their standard (usually about 700 lb/in) springs to better handle heavy bumper, winch, lots of towing, etc, and could set you up.
Though you may find with better shocks (and the ability to adjust the coilover to make up for the sag) you don't really need springs that are much stiffer so don't be afraid to try the off the shelf spring first if you find a really good deal.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 484 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
