78 gmc heater temp control
My heater control valve is missing from my truck and in looking for a replacement I have found that there are 2 different ones, 1 rpo code c41 and the other rpo code c42 and seeing that I dont have the old one to compare with I am trying to figure out which one i need. Is there any way to tell which one I need? Thanks in advance for any help!
Is there a Pick-A-Part near you?If so go there and look around,you might get lucky and see an example of what you need.
I think I am going to check the local pull a part, they have several 73-87 chevy and gmc trucks and given the low cost I will grab a couple different ones and try them. My RPO code sheet is missing so I dont have that to work off of, I dont suppose I can use the vin to make another sheet? Thanks
