Any used a P3 -AND- the GM Brake Controller in Current Gen?
I have a '15 Sierra SLE with the factory brake controller installed. Have not used it at all, and am looking to get an equipment trailer that will require a brake controller.
I also happen to have a like-new Prodigy P3 brake controller that I used in my last full-size truck with a 10k trailer and was extremely happy with how well it worked.
My question is to those that have used BOTH the P3 -AND- the current generation integrated controller and can offer some comments on whether one is better than the other or not. If you have used a P3 and the integrated factory controller in a current gen 1500, that would be about the cleanest comparison I could think of.
I'm not directly looking for comments about whether one is great or poor... Only in search of comments dealing with a direct comparison of the two as I'm wondering if I should disconnect the factory controller to install my P3 or if the factory controller works pretty well.
Let me start by saying I typically only have the need for a brake controller a few times a year. That number is likely to increase since I sold my single axle non-brake trailer and upgraded to a tandem brake equipped one. I previously towed rented and borrowed brake equipped trailers.
With that said, I used a P3 in my old truck, and have the integrated in current. I've towed the new combination a few times, including an approximately 3000 mile trip. I find the integrated easier to setup and adjust. It's in a more convenient location to adjust and monitor in the DIC.
The biggest benefit I see is the claim that the truck will automatically engage the trailer brakes when the truck's computer detects trailer sway. An aftermaket controller can not do that.
Good feedback - thank you.
I hadn't thought about the sway issue, but it makes sense. Truth be told, however, I typically do -NOT- like my vehicles automatically engaging the brakes in any capacity. I simply do not trust them to do it under the correct circumstances. I've had some sway creep up on me before and a quick and gentle squeeze of the manual brake control on the P3 settled it right back down. Since these trucks claim to require a WDH with anti-sway over 5k anyhow, there should be little need for that.
I -really- like the P3, and have absolutely zero experience with the integrated. So, I'm trying to figure out if I'm going to be happy with the integrated controller with the small amount that I tow.
I see your point, but you can't really get away from much of it.
You still have the ability to manually engage the trailer brakes with the slider at will.
My thinking is if I need to make an evasive maneuver I like the idea of the truck engaging the trailer brakes if needed. Since I do not tow on a consistent basis it would not be an automatic reaction for me to grab the slider. I think my concentration is better spent dealing with whatever issue caused me to take evasive measures. In times of "crisis" if you will, there's no time to think, your body reacts based on previous similar situations or training.
Another thought I had when deciding if I wanted to keep my P3 or not.... The unlikely chance of trailer brakes engaging when not really needed is much better than a situation where the trailer should have brakes applied and I was unable to react quick enough.
And that "evasive maneuver" sort of scenario is what would concern me the most with the integrated controller. The truck isn't going to "know" that I'm turning to avoid something, it's just potentially going to sense what it thinks is "sway" and may attempt to apply the brakes. My wife's car has the "Collision Avoidance" garbage in it, and I have been surprised on more than one occasion (as was the driver behind me) when the car applied the brakes hard because of a car well out in front of me that was slowing to turn out of the lane of travel.
Anything requiring a panic stop of sorts is going to be handled fine by the P3 as it has the motion sensing in it to determine how hard you've hit the brakes so that it can adjust the braking force on the trailer. I'm sure it would be handled very similarly by the integrated controller unless it uses detection of the attitude of the truck (as opposed to inertia force) to determine how hard the truck is braking.
  • 3 weeks later...
In my opinion as a trailer tech... I agree and disagree with all statements above. The integrated controller is a very simple controller to use. It does the basics that you need it to do. I have one in my 14 Silverado and it does the job quite well. I have been in different driving conditions and have never seen it automatically "kick in" to stop trailer sway. I also strongly believe in using the proper hitch setups (wdh/sway bar(s)). The P3 is a great controller, you can preset brake output levels and it can control and power heavier magnets that are on heavier trailers a lot better than the factory one can(voltage and amp draw are considerably better).I also tell my customers that if they want something a little better than a standard controller to then get the Prodigy P2 controller. Exact same as the P3 just that the P3 can do electric over hydraulic brakes as well just not electric. So depending on vehicle and trailer and amount of towing would be my final decision... for my current applications I use my 14 Chev I am happy with the integrated controller but on the heavier hauls my truck has the P3.
Thanks for the thoughts and input. Interesting to read.
While I like how "clean" the integrated controller is in terms of looks, I personally don't like it on the left of the wheel. If I have only one hand on the wheel at any given point, it tends to be my left. Reaction times and such to bring the right hand to the wheel and the left hand to the controller are not as good as just bringing the right hand to the controller to manually apply brake.
I'm looking at swapping in my '15 Sierra DC for a '15 Silvy CC and the second truck doesn't have the integrated controller. So, I would end up wiring in my P3.
How heavy is "heavy" when you're referring to the heavier trailers with larger magnets? I had a 10k Anderson equipment trailer that I dragged using the P3. I'm picking up a 10k Big Tex this week to pull using the integrated controller. Is that "heavy enough" to realize in difference in controller performance?
Considering trailer brakes don't really start showing up until you go North of 3k, and the trucks -generally- aren't rated to pull more than 10k (in addition to the PITA it is to register a trailer above 10k in some places like it is in CT), I would like to believe that these trailers are all within the capabilities of that controller. But, I just don't know that for certain. Thoughts?
I had the p3 in the truck traded and I have a 15 with the GM intergrated controller. Both work for imo. I tow a 6k lb travel trailer. Both are very smooth braking. Can't go wrong with either. I do really like the p3 though. But the factory one works great too and the lower dash is cleaner
The integrated controller is fine the way it is... By when I meant heavier trailers I mean heavy such as 21k trailers. That's where I prefer the P3 over the factory any day.As far as your trailer that you are getting you will be fine. The integrated controllers are designed mainly for 2 axle trailers with 7000lb axles they can handle more but that is their basic design.
I just bought another truck for the shop... 2015 Chev 3500... it has the integrated controller but with some of the trailers I deal with I had the dealership deactivate it and then I installed my P3.
Hope that helps.
Thanks... It does.
I dragged the new trailer home today - 150 miles in torrential rain. I have to try different settings on the controller to get it "just right", but it seems that a gain setting of about 1.5-2.0 is what works best to stop the trailer (2500 lbs empty) while the truck's brakes stop the truck.
Any input on gain settings versus weight?
Does it remember the setting it was on the last time you used it?
Why can't I apply enough brakes to the trailer to keep the truck from moving forward? It seems I have to crank the gain way up to achieve that, and that's far too much braking power on the trailer when it's empty.
I also noticed that the amount of braking power applied to the trailer appears to be directly related to how hard you press on the brake pedal (you can watch the amount of braking force slide upward on the scale while sitting still if you press harder on the pedal) - THAT'S a nice little "extra".
As far as gain settings versus weight my only advice is that once you change the trailer or the trailer weight then adjust the controller to what feels best for you and the truck... obviously it will react differently when the trailer has been changed.
Yes the truck will keep your settings everytime. Once you change the settings it will remember the last setting it was adjusted to.
As far as the trailer brakes stopping the truck that can lead to a few possibilities. First the controllers in the truck only put out a maximum of 10.5 Volts... not a full 12 volts. Therefore it will not put maximum power to the magnets but still enough that it should hold enough brakes to stop the truck... Other options could be the trailer brakes themselves... if the brakes are new on the trailer then they actually need a break in period and 2-3 adjustments done on the shoes... Dexter axle recommends having the brakes adjusted after the first 50 and 200 miles of installation of new shoes or drums. So your brakes on the trailer could possibly be out of adjustment and just need to be set again.
Trailer is brand new... Towed it home yesterday, about 200 miles. Need to check the lug nuts, and I'll take a look at the brakes as well (I don't like it feels like they 'hang' after stopping and don't release fully until you've rolled a few feet).
Follow-up question on the integrated controller:
I noticed that the trailer brakes seem to remain at least partially engaged after stopping at a light or intersection (or whatever) until the truck has rolled forward a couple of feet. Does the integrated controller continue to provide power to the trailer brakes along the lines of "Hill Start Assist" in the truck until it's sure the truck is underway under its own power? The trailer brakes release with a sort of "thump" after the truck has started moving. The trailer uses the Dexter axles that require no adjusting, so I'm guessing that it's -not- something that needs any sort of adjustment on the trailer (could be wrong).
I have towed medium weight (up to 15000) trailers all my life. The integrated controller does as well or better than any aftermarket one I have had. For a load only a new HD can handle, is the P3 really better?
As far as I know the hill start assist does work with the controller as well. There will be a delay with the trailer same as the truck. As you try to move forward it will have a thump because the power to the brakes is still on and the once the assist releases it will then release the brakes.
As far the heavier loads for HD trucks yes I do believe the the P3 is better on heavier loads. The trailers that my 3500 hauls are 7k triple axle trailers(21000lbs). With the integrated removed and p3 installed I do notice that I can apply more power to the brakes. I do believe the integrated is a good controller and can handle most trailers but like I said on the heavy loads my 3500 does I really do recommend the P3.
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,477 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
