Does anybody know if the tailgates on the silverado and sierra the same? Same with short, regular, and long bed; also 1/2, 3/4, and 1 ton.
I looked at the part numbers and they show different for short, long, and regular bed.
So are these interchangeable or there will be a fitment issue?
I think the only thing that might be different between trim levels is the tailgate cap. Nicer models will have a thicker, heavier duty tailgate cap. Lower trim will likely have a thinner flimsier version.
2014-2016 1500, and 2015-2016 2500hd/3500hd, both Chevrolet and GMC use the same tailgates. There are only two part numbers, one for tailgates without the tailgate lower/raise assists and one without. No differences in the top plastic cap, that was a 2007-2013 thing, and even then, there were two tailgates used by both, one with assists and one without. Both top caps would interchange as the gates were designed to accept both. Even 1999-2006, same gates.
  • 3 years later...
4 hours ago, [email protected] said:
does anyone know if a 2015 tailgate will fit ok on a 2017 GMC Sierrs 1500 ??
Welcome to the site.
What trim level is the 15 from, and what level is the 17?
Thinking your answer is right above your post.
  • 1 month later...
  • 4 months later...
20 minutes ago, Sublimmy said:
Will a 2018 Silverado power tailgate work on a 2016 Silverado? Is there any difference between the 1500 and 3500?
I don't think there is a power tailgate for the K2 or even the new T1 trucks. Do you mean the "E-Z-Lift" tailgate? That's just a torsion spring inside to make lifting and lowering easier. Tailgates that will fit your truck are years 2014-2018 1500-3500. They all are dimensionally the same.
  • 1 year later...
  • 1 year later...
  • 1 year later...
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,211 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
