17" wheel size?
I have a 2015 Silverado LT with 17" wheels - anyway to find out or does anyone know if they are 17x9, 17x8, etc?
not even sure if that matters but I'm looking to put some 33's on them...33x12.5 seem to be the most common size. I will be adding a 2.5" leveling kit.
Should say on the back side of the spokes. Another way is find out is find takeoffs on ebay and see what the seller lists as the specs. Check a couple to verify.
Sent from Tapatalk App - Samsung S6
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
