2014/2015 Sierra SLT LED DRL Headlights For SLE
mafd2
Here is an awesome new set of GM Sierra SLT LED DRL conversion headlights that will work on SLT's or SLE's without using the special 3 relay headlight harness that also requires an additional 12V source to the fuse box. Even getting SLT lights for your SLE and using the special harness, you will still only have bottom DRL's during the day and top/bottom LED's on low power at night. This new conversion set up eliminates that. These lights have high quality switchback LED's from Diode Dynamics that carry a 3 year warranty. Top and bottom LED's are a bright white and stay on high power which are powered by a 12V source. All you need is a micro fuse tap in the fuse box to supply the voltage to the LED's (see picture) or a 12V source of your choice. Many Sierra owners want the LED's in their stock headlights to stay on full power and not go to low power at night but there was no way of doing it. These also have switchbacks LED's. The clear LED's go off and the ambers come on when the turn signals are used. No additional wiring or harness is needed for this function. It is all professionally pre-wired plug and play for SLT's or SLE's. These also have clear corner lenses installed with amber bulbs. Also installed and included are 5300K super white German halogen bulbs to close match the DRL's.
For those SLT owners who want their DRL's as top and bottom instead of just bottom and to stay on bright even with the headlights on or SLE owners who want headlights with DRL's and the same functions mentioned, here they are. Price is $1500 + $25 shipping which is very fair considering the price of the headlights, LED boards, clear corners, new 9012 bulbs and labor.
We have done 2 sets of these. One with clear corners (as pictured) and one with the stock ambers for those who prefer the amber look corners. Here is a video link demonstration of the lights. PM me with any questions and thanks for looking.
do the LEDs have to go amber when you activate the turn signals? or can we keep the white LEDs running and just have the standard amber turn signals?
That's the way the switchbacks are wired. The amber LED's will blink with your stock turn signals. If you apply the right turn signal the right headlight will blink amber while the left headlight will stay white. It's only the side of the turn signal used that turns amber. If you use the emergency flashers both headlight LED's will blink amber.
Thats a pretty sweet setup. Whats the warranty on these lights? Im interested in a set of lights with clear corners. Thanks.
There is no warranty on the headlights from GM anymore because the lights have been modified, however the LED's carry a 3 year warranty from Dynamic Diodes. The lights are carefully sealed using extra butyl. I don't have another set with clear corners but do have one set left with switchbacks and amber corners. These 2 sets were done at a discounted price for promotion to get them out there. After this last set, they will be around $1800.
What if we were to trade headlights to reduce the cost? I might be down for the amber corner one, if so
  • 2 months later...
I have a new take off stock set of headlights from a 2015 Denali with the harness as well to use on the SLE. These aren't the custom switchbacks and are stock LED signature headlights. PM me if interested. Thanks
Do you guys modify sle headlights? I have the sle headlights without leds and would like to switch out the amber reflector with a clear or smoked one, as well as blacking out the chrome
Sent from my SM-N910P using Tapatalk
    small navy
    small navy
  • Who's Online   5 Members, 1 Anonymous, 662 Guests (See full list)
