Infotainment System - Blank Screen
gemsierra
I have a 2014 GMC Sierra with the infotainment system. The main screen went black yesterday but everything still worked you just couldn't see what was on then screen. I figured it was just a one time glitch because the system is known to do odd things like that. But it stayed blank when I shut it off for a while and even disconnected the battery for a while and still nothing. Has anyone else had this persistent issue or a similar one to it?
There is a software calibration for this that also fixes a lot of Bluetooth issues.
I have a 2014 myself and have had that happen 3 times so far. It usually comes back after a little bit. I am waiting for an oil change to tell the dealer. I hope the update also fixes the voice commands because 75% of the time it doesn't get it right and I try to speak as clearly as possible.
Yeah I thought it would come back after a while to. Its been three days straight and I have disconnected the battery over night twice and the lcd has not come on at all. I think it might be more than just a software issue because i have had it black out before but it usually comes back on if you restart the vehicle. Im anxious to see what my dealer is going to have to say. And yes the voice command is usually a hit or miss with me to.
This just happened to my 15 today. Won't come back on at all. Have to see what dealer says. This truck has spent more time at the dealer than my last 6 trucks combined. Ridiculous.
I had this happen on my '15 2500. First time it went out on Monday AM, stayed out through to Thursday when I got truck into the dealership. They said the reseated a connection and added dielectric grease. Went out again the following Monday morning. Tuesday morning it was working, took it into the shop anyway. The found a bulletin for "a similar problem" which involved adding one or more additional grounds to a BCM, they didn't go into details. While they didn't tell me or document it; I know they found an additional loose connection behind the dash. Banging on different parts of the dash would cause the display to come on/off.
Initially, the mechanic tried to blame my accessory switch box and aftermarket backup camera.
  • 4 weeks later...
New owner of a 2014 LT with the 8 inch infotaiment screen. As it's a used truck, i figured I would need to replace the cabin air filter. When I was done, I turned the truck over and had like you described - black touch screen, but I could press the screen and stuff would happen....
Removed lower glove box again, started truck and screen comes on. With it running, I put it back in and as I pushed in the lower left corner the screen went out. Seems like there's a harness in there that can get pinched. Totally weird, but totally happened!
Made sure to insert the box slowly and this time it stayed lit; so all good and no reason to go to the dealer and go crazy...
  • 1 month later...
I had this happen to me this summer. The 8" LCD display would go out completely at random. Only restarting the vehicle would correct the problem. The issue could not be reproduced on demand. Visited the dealer twice on this issue. They could not reproduce. So I took a pic of the issue with my iPhone to show the dealer. I also got GM customer service involved and they reached out to the dealer to figure out an action plan. They couldn't reproduce, yet they had the photo showing the LCD completely blank. The XM radio continued to function though through the steering wheel controls though the responsiveness of changing XM stations changed to 5-6 seconds lag time to go up / down 1 channel. The first trip into the dealer they reflashed the firmware, which the dealer stated was based on guidance from GM. The second visit they told me nothing was wrong, which is the point I complained to GM customer service. Who I must add they were extremely helpful in getting this resolved.
Ultimately, the GMC dealer replaced the 8" LCD display with a new unit.
The problem has not occured ever since and is completely resolved.
  • 2 years later...
Just used this method and it worked. I too did my cabin filter and the screen went out. I started the truck and moved the wires around. Screen came back on. Thanks
    • As the title suggests, I have an unused General Motors authorization code for a set of bed perimeter lighting lamps that I bought. My truck was built with the option for perimeter lighting, and they worked without programming… So now I just have this code. What is it good for now? Can anyone here use it?
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
