Clunk/popping noise after level
Anyone figure this out? I believe I have picked up the noise 6 days after installing my 2" upper strut spacer.  I will double-check torque or sway bar and tie-rod bushings this evening.
I had this noise when I pulled into my drive way or backed up. I replaced the control arms as the ballpoints can’t be changed and the noise went away
  • 4 weeks later...
  • 4 months later...
I just spoke to the dealership yesterday and they are aware of this on the 2014 to 2018 trucks. They said it is the front track bar and it needs to be retorqued to factory specs. $170
  • 2 months later...
@ DBrach have you tried the retorque on the track did it work and has anyone else figured out a fix. I have a 2.5 levevling kit on my 2018 with 3k miles on it have made sure everything was tight but still have front driver pop/clunk noise at low speeds and bumps
  • 8 months later...
bump... Same problem.
3" lift/level in front.   New UCA.   44k miles.   Started happening around 30K
I was having almost this exact same issue and could not track it down - turns out on of my upper control arm bolts which I thought were tight were actually stuck / giving the false indication that they were tight - I had to loosen and re tighten, finally I am free from that noise. Hope this helps
  • 2 months later...
Hello all,
So in 2018 I put 3" Fabtech lift on my 2018 Gmc Sierra Denali with magenride. The kit comes with strut spacers, Uniball upper control arms, and blocks in the rear. The kit cost me about $1,000 so I thought that I wasn't going cheap. However, when I first put the lift on I always noticed a very noticeable pop noise on the passenger side whenever I would go over small abrupt bumps while going straight or turning at low speeds. the noise annoyed me too much so I took it to all types of dealerships and shops and no one could figure it out.
Eventually I got tired of it and invested in a by pass kit that allowed me to put full length coilovers in and completely remove the spacers (because I thought the problem had something to do with it). So I completely removed my factory magneride suspension and installed Fox 3" Fox 2.5 Coilovers in the front and 2.0 Fox shocks in the rear. First thing I noticed was that the sound had now moved from the passenger side to the driver side and it was not as loud, but it was still there. I was livid because I just spent another $2,000 on this fox suspension and I'm still getting the noise. Again I took it to many shops and dealerships and no one could figure it out. The dealerships told me it was the shock so I sent it to FOX and had them look at it a rebuild it, but nothing was wrong.
I also had the shop re grease and replace the bushings on my upper control arms and basically do the whole nine yards to make sure everything was tight and good to go. Still to this day I still hear the same pop pop pop intermittent noise when I go over small bumps or dips or anything sharp. my truck rides great on the high way it's just if I ever try to take in any rough street or off road conditions it is absolutely awful and the truck is popping the entire time. I literally do not know what to do and I do not want to keep putting money into the truck if I don't absolutely know if it will fix the problem. does anyone have any solutions?
  • 1 month later...
Just had A RC 3.5” lift installed. Got the same clunking noise immediately. Anyone been able to find a fix without replacing the rack that seems to keep failing for other people? Tracing the noise down, it lead me straight to the center of the electronic  steering rack. Most likely a gear? Or is the steering bound up by the dynamics of the suspension?  My knuckle kit is designed to keep the dynamics of the factory upper control arm adapted with the knuckle. So how could anything be bound up causing noises? I also hear some have removed their lift and gone back to factory with the noise disappearing completely. Just way too surreal for a night and day change like that..
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
