Where did anyone get 7443 LED canbus warning canceler
Payton34
I have Philips vision 7443 LED but the Philips canbus I used that taps in the wires didn't work and I tried all 3 wires still didn't work. I have seen cancelers on amazon with the plugs built in but don't know if they are any good.
Could I get a LED flasher relay I didn't know the newer trucks use flasher anymore.
I know some guys have switched to LED bulbs what did everyone use to get rid of hyperflashing.
  • Replies 31
They are generic 6Ohm 50W resistors, run them in parallel to the bulb then you are golden :)
Ditto. Just resistors run in parallel with the circuit for the turn signals.
Forgot to mention resistors have no polarity, they can go in either way as long as they are in parellel with the bulb
I used the Philips 21W CANBus Warning Canceller for 7443 and they didn't work. Which color wires do I attach to. I think I tried all combinations. There are black grey and green.
What type of resistors do you use do you have a pic?
I tried that and hacked up my harness. Got the top bulb to work, but the bottom bulb socket has really short wires that splice into the main harness. Which wires do I connect into there? Tried every combo I could, still didn't work.
Of coarse I am talking about putting LED bulbs in the Silverado tail lights.
The ones on amazon are 50W the Philips resistor is only 21w but says it is for 7443 bulbs. Is the 21w not enough
I tried again black and green wires with a philips resistor at each bulb and they hyperflash and also alertsnate top is on bottom is off. I then swithched colrs wires on the resistor and still same problem
Can you take a picture of your wiring? it has been a long time since I have popped open my back lights. Pretty sure it was one to black and one to green.
Well the resistor I ordered with the plugs didn't work at all bulbs wouldn't light up at all with resistor pluged in
Looks like those resistors only work for 7440 bulbs. You need them for 7443/7444 bulbs
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
