2014 level kit with Bilstein adjustables
clayface
2014 double cab. The previous owner already has bilstein adjustables on the front, so the truck sits basically level. My question is, does anyone know how much lift that adjustable front shock gives on the top notch? I ordered a 2.5" front and 2" rear, plannin to get 3.5" ish total in the front. Am I wrong or right here. And will it sit level?
1.8" at the top setting
I don't think you will want to go that high with a level kit, you are asking for trouble down the road with suspension parts wearing out. If you want that much lift than you really need to look at a true suspension lift.
You won't like the ride once you add a front 2.5" lift. It will be wayy stiff. Other than that your front UCA will be beyond maxed out and if you are 4x4 I'm not sure if you will need any additional components to get the truck riding right.
+1 .. I had those shocks with a 2in level.... the ride was garbage even at the stock height setting. I dumped it all and got the Rancho quicklift.
You still happy with the rancho quicklifts? I am going to raise mine up in the near future and was going to go with the Bilstein on the next to top setting (1.25 inches I think) because I really don't like the perfectly leveled look, like a little rake. I do like the price and easier installation of the quicklifts though.
So I guess I'll drop the bilstein to the 2nd setting (1") and put my spacers on with that. Hopefully that balances everything out.
Buy balljoints now and get ready to replace them in 5k
Just to make sure, I was supposed to take out the factory rear block, correct? They weren't meant to be stacked right?
Do not stack blocks. also a proper 3" to 3.5" lift requires new upper control arms and steering knuckles as the stock suspension geometry will be maxed out with stock parts. A leveling kit at 2.5" has the upper control arm nearly maxed out already hence why the ride is bad after. Look into a ready lift 3" or 3.5" kit. In the long run you'll be happier
Sent from my SM-G900W8 using Tapatalk
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
