Want to Clay Bar my truck but have ?'s
I have a 2002 GMC Sierra with a Black clear coat and would like to use a Clay bar in her (along with a good polish & wax) but need to know how to apply it properly.  I've heard that on dark colors Clay bars scratch the paint or like 2k2TahoeSS case it messed up his door.  Please let me know what works from your experiences.  Thanks.  :crackup:
I used the mothers clay bar and quick detailer stuff on mine.  Didn't notice any scratches on it,but it is pewter.  I did it in the garage, adn put down a plastic drop cloth in case I dropped the bar.  All you have to do is make sure you put on enough of the spray stuff to keep the clay slippery.  I used almost the whole bottle!  but if you do a 2'X2' square at a time, you should have no problems.  But it came out glass smooth, can't wait to do it again!  Good luck.
Done appropriately, clay bar cleaning is simply amazing. Lubricate, lubricate, lubricate.  The previous poster was not exaggerating in his instructions.  He is right on.  And, if you drop it, and if the plastic sheeting on the driveway is not clean and free of sand or stone, get rid of the clay bar and use another.  If you kick sand, or if the wind blows sand on the sheet...  ouch.  SORRY!!!
I first learned of the clay bar technique by seeing it done at a local body shop in which paint overspray was being removed. The shop would wash the vehicle until there was absolutely no grit on the body.  Then would then clay bar the body panels.  The guys would go through a bar a week.  They told me to use Windex for the lubricant and for me, that seems to work great.
One suggestion, practise on your refridgerator or freezer, if it has a smooth metal design.  Get comfortable for the feel of the bar, and how it behaves when it needs more lubricant.  Then graduate to a small section of your body panel.
After you get finished, rinse the vehicle off very well.  Indeed, wash it until it is really clean, dry it, then wax it.
Clay bars work great.  And like everyone said, just keep the surface that you are claying very wet.  And be sure to wax your truck after you clay it. I've heard that the clay bar will strip the wax off of your paint.
I have to agree that claying will leave the paint absolutely smooth.  The clay will take off the layer of wax and whatever else that is on the outer layer of paint.  Just a couple of tips in addition to what the others have said:
1.  Break of a smaller piece of clay to use.  Keep it kneaded to increase the clean surface that contacts paint.  This will reduce the chances contaminates picked up from scratching the paint.  Definitely do not use it dry.  And this allows you to still have pieces of clay left if you do drop it.
2.  Make sure you do it in a shady spot on a cool surface.  Do not use it in direct sunlight.  A surface that the sun has heated will melt the clay onto the paint and dry the lubricant too quickly.  This will leave the paint dull.
3.  Take your time and clay a small spot at a time and wipe the lubricant before it dries on the paint.  This will also allow for you to look at and feel the condition of the paint you just went over.
Good luck and happy detailing.
i concur with everyone above. use alot of water and soap, and wash the vehicle good beforehand!
I use a bar of Zaino clay for EACH vehicle!! :cheers:
Once you go over it, i don't think it really matters about letting it dry. I just wash the whole vehicle again after i'm done.  :)
Just make sure that if you drop it on the ground, you toss it, dont even try to clean it out.
Dawn dishwashing liquid FIRST TIME ONLY, and then go for it. It should never "grab" it should feel like you are almost not doing it right. It should just slide across the surface. You will look at the clay when you are done and think WOW.
I used on my Black vette, and my dark green vette. It is great on the dark cars. My current red car and Pewter Tahoe it is beautiful too.
Just plan to take your time.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
