Hi all
TheStig
New member here. Have a couple of Silverados in the stable. My wifes '14, and my '95 that I just picked up for next to nothing.
The roll bar will be coming off this weekend, and overtime will get all new lights all the way around.
Picked up some 18s for cheap, and straight piped the truck, with the front resonator still in. Sounds really good. Hoping to fab up a homemade intake soon.
Anyways, I look forward to learning more on this forum, and hopefully have some valuable contributions.
Sent from my HTC One_M8 using Tapatalk
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
