Brake Caliper Covers
Truckin 55
attachicon.gifmgp_14004-S-BOW-BK.jpgattachicon.gifmgp_7417_chevy_silverado_1980_2015.jpg
Opinions on Brake Caliper covers , like the black with logo but expensive $199
I also am digging the black bowties, as i just had a similar logo made for my wheels
I also am digging the black bowties, as i just had a identical logos made for my wheels.
I swear, you guys gotta stop finding new add-ons for me to spend money on! Damn it! Btw, my wife hates all of you lol!
buy her some jewelry and then start back on your truck
Im afraid to even ask, but where did u find these covers...?
I'm gonna paint mine the color "maze" over the winter months... GO BLUE!
Carid don't know who else sells them , MGP is manufacturer .Painted the Calipers Red on a 04 Monte Carlo SS and exhaust Semi Gloss Black looked really sharp,lost pictures when old LP crashed
I am glad i have a motorcyle to spend my $ on or i would need these
Sent from my SM-G920V using Tapatalk
Couple buddys have painted there, and they havnt held up all that great
Gotta prep them them I have clear coated mine
Ryan
It's all in the prep work....They have to be very very clean and scuff them good and then paint, don't rush your work and they will come out good.
RT
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 696 Guests (See full list)
