Brake Caliper Covers
Truckin 55
Until I buy a real brake kit I'm running these. Covers are off Ebay, rotors and pads are from EBC. They look great, but you really can tell a difference in the pads and rotors. Big improvement over stock!!
I agree to paint them. I have painted a few cars in the past. If done right it last a very long time..
Those covers are just cheap looking. IMO
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 693 Guests (See full list)
