Stubby antenna solution.
ErickW
Hey guys just wanted to pass this along. I installed my leveling kit on Friday and immediately realized a problem I hadn't thought of, but had with my old F150 when I leveled it. Antenna scraping garage door and opening. I found this stubby antenna at the local auto parts store for $18 and it works perfect with no reception loss at all. So anybody looking may want to look into this one as well. Its made by Metra and the model number is AWRMCF.
[/url]">http://3507F738-8236-4AC1-894C-973F997A61FF.jpg
[/url]">http://http://s298.photobucket.com/user/ew3634/media/Mobile%20Uploads/2015-11/AD4EBDDB-F991-40FF-9C0C-89B078C464FB_1.jpg.html'>AD4EBDDB-F991-40FF-9C0C-89B078C464FB_1.j
[/url]">http://AD4EBDDB-F991-40FF-9C0C-89B078C464FB_1.j
Thats pretty cool, but i like my full size antenna... I use it to let me know cab clearence when i go thru low ceiling parking garages in my area, which i frequent
This isnt new, us GMT900 guys have been doing this for years
Where did I say it was new? I was just giving another option for a stubby antenna aside from Craven Speed, antennaX etc... Thanks for your input.
I love my stubby too! Although I noticed the other day my stubby has lost its finished and is no longer black.
Sent from my SM-G900P using Tapatalk
Don't you hate it when your stubby loses it's finish - maybe you're polishing it to much.
I've been thinking about doing this. My antenna rubs the garage door now, which isn't so bad, but it seems to work it's way loose after a few weeks.
That's the only reason I've done it with my past two trucks, it just annoyed me when I pulled in and out of the garage, not to mention scratching the opening and the door. Plus I thought this little antenna was kind of cool looking
