3 hours ago, AJE said:
I was curious about this myself.
Manual mode number displayed is the maximum gear number currently available -- which is not necessarily the 'current' gear.
Drive lets trans use 1-6.
M4 lets it use 1-4
M3 lets it use 1-3
and so on.
Manual mode doesn't/can't force it to upshift.
  • Replies 37
M4 lets it use 1-4
M3 lets it use 1-3
and so on.
I may be mis remembering because my Toyota will let me upshift at will in manual mode to a point. I thought my 14 GMC did, otherwise what’s the point? Come to think of it my Genesis will to.
M4 lets it use 1-4
M3 lets it use 1-3
and so on.
I meant to have the current gear displayed when driving in "D".
GM ones will upshift, but only if the rpm/load is such that it would have upshifted if it was in drive.
M mode does no allow operator  to 'force' it yo upshift at a lower load/rpm than what it would on it's own.
For example, you can drive around town with it in M5, and if will downshift/upshift for stops in traffic the same as it would in D.
Only difference is it will not go past the gear selected  (5th, in this example)
Yes, I realized that.
I was just pointing out that when in M mode, it doesn't show the 'current' gear either.
I can’t remember on GM, but my Toyota will let you go one gear up as early as you want. I never tried two. I remember some Fords would back in the day great for smoking the tires. GMs wouldn’t I use to disconnect the kick down and install a shift kit so I could shift early on GMs 3 speed autos. Good for burnouts. I was a bad boy.[emoji41]
Oh...  I thought it did when I used it (only tried it out while messing around).
I 2nd that ... can I get a third?.... a first?...
I think if a Tech can change the display code, might make a pretty penny....
    btm
    btm
  • Who's Online   7 Members, 0 Anonymous, 1,468 Guests (See full list)
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
