The mod bug has bitten....suggestions?
I have a 2005 Sierra crew 5.3 (virgin) and can no longer resist the urge to start upgrading. It's bone stock with the exception of the previous owner putting on a single Magnaflow and dumping it behind the cab (which i don't care for). Looking for suggestions on where to start the process. My initial thoughts are full exhaust, headers (longs or shortys?), intake, cam and tune...in that order....
Go
Sounds like a plan! Get full-length if you want more top end, shorties if you want more bottom end. For an I take, I'd go with Volant. They have pretty awesome kits, and I believe you can buy a valance scoop for it too. Are you looking at any suspension mods?
Sent from my Vortec-powered Droid Turbo using Tapatalk
Well I'm currently sporting a 2/4 drop, its 2WD so i figured i'd stick to the street truck course
I've read elsewhere on this forum that the intake boxes are good and just changing the intake tube is a good step???
Long tubes for more POWAH!!!
I've been told the long tubes are considerably more difficult to install compared to shortys and not worth the extra work? I'm not scared of the work if its worth it...
Exhaust.... I want this mofo to scream when i open it up but don't want it to be ridiculous all the time. My plan was running 3" all the way back, high flow cats (if any) and some sort of muflers (I don't really know which ones).
Honestly I do not know. I've never installed headers.
But I just know that everyone says long tube's provide better power gains vs shorties.
My suggestion;
3600 stall, 3:73.1 gears (cryod), trans go shift kit, and trans cooler (if you do not have one).
JMHO
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
