E rated tires psi
There is no reason to run the air pressure that high when it's empty; it only makes for a harsh ride. An E-load tire at a lower pressure can take the same load as an LT tire at "specified" pressure level. Is the harsher ride desirable?
That is wrong, an E rated tire is an LT tire. Go to Toyos website and download their inflation chart (applies to any brand of tire). A P rate tire can actually hold more weight than an LT tire (C,D,or E) at the OEM PSI which is usually around 35 psi. The chart will let you figure out the required PSI based on a switch from a P rated to and LT rated tire as well as going to a different tire size. For most around 45 psi on a LT tire is equivalent to running 35 psi in the stock P rated tire. The load range of the LT tire does not matter (C,D, or E), they will all be run at the same pressure to handle the load rate that the OEM P tires are supposed to handle. Running an LT tire at too low of a pressure can cause it to heat up and possible have a tire failure. Running them too high will just cause them to wear out in the middle and give a much harsher ride. On my old 2002 I rand Cooper AT3 load range E at 46 psi because that is what the chart showed was the same load range rating as my stock P rated tires. On my Ford work truck I run them at 44 psi on a load range E (what the chart showed from going to a bigger LT tire from the small stock P rated tire).
  • 4 years later...
275/70r18 BFG KO2 on double cab 4x4 Silverado. 3k miles so far on tires. 78k miles on the truck. The psi was Too low from tire shop.....then tried 52 psi for a bit.....settled on 47ish psi for now. Rougher than stock ride and a bit louder but so far very impressed with the tire. Driving on Winter and harsh roads in Ontario.
  • 3 weeks later...
I have 35x12.5 r20 Toyo RT and I called Toyo and they said 35psi for my truck. Call them they will ask make model of truck and tell you the correct psi for the larger size tire. there is a conversion chart they also have on the website to convert from stock tire rating and psi to e load psi for 1/2 ton truck.
You can do the tire chalk method as well. Do this a couple times and find the right wear pattern to get good life out of the tires
I have Nitto Ridge Grapplers 37x12.50x20 and Nitto says to run these at 30 psi cold. Wonder why yours are supposed to be 35?
The best thing to do is run it at the pressure you need for what you are doing at that time. My tires are one pressure if I am on pavement, different if towing, different if my whole day is going to be off road in soft soil and dirt. Also, my front and rear are always different because of weight distribution.
Sent from my SM-G975U1 using Tapatalk
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
    • Did this ever get solved?   I'm chasing 2021 Yukon Denali electrical issues - vehicle will not enter sleep mode - we can disconnect and reconnect the battery and it will sleep - but that's likely because we powered down whatever module doesn't correctly sleep.  once we start/accessory the vehicle and turn off, it will stay at 11.5 amp draw with something keeping the SDGM alive - it appears to be activity on the X2 segment, specifically CAN FD Bus 5 - but we don't know which device and we think we've already isolated all of the devices on that segment - so what keeps the BCM and/or the SDGM alive is unknown.   I don't yet have a packet trace from CAN 5 (and since this Global B we might not get much info from it) - but the vehicle has been down for 8 weeks and previously GMC Dealer was unable to resolve "kills battery" issues with this particular vehicle - so I'm at a loss - it seems to be beyond local repair capabilities - and the number of "telematics keeps vehicle from sleeping" posts indicates this whole architecture has major issues - I hate to say it, but we might have to install a battery cutoff switch on the front grill - one of those red boat switches - to turn off the vehicle.;)  Any pointers appreciated;)  I just bought a CAN FD interface and I'm planning to try Savvycan and Peak Can SW to triage this further.
