8 Speed with the 5.3
I've been looking forward to getting a new 2016 LTZ/SLT later this year and I was looking forward to the new 8 speed transmission. This evening I was browsing the local dealerships online and I noticed a 2016 SLT with a 6 speed transmission. I thought this was strange because I was under the impression that the 8 speed was standard with the LTZ/SLT trim.
I've built several trucks on both GMC's and Chevrolet's websites over the last month or so, and today was the first time that I noticed that the 6 speed is now standard. Is this a recent change or could this be a mistake with their websites?
Also, if I select the 8 speed it now requires the max trailering package...
My 2016 has the 5.3 and 8 speed but I don't have the max trailering package. Far as I can tell, 6 speeds go in the double cabs and 8 speeds go in the crew cabs.
Depends on which cab.
Crew slt 5.3 has 8 speed.
double cab 5.3 has 6 speed. (DC 6.2 still gets the 8 speed)
At start of 2016 model production DC 5.3's got the 8 speed as well
The week of 11/23/2015 production update, the dc was changed back to the 6 speed.
At least one forum member has a 2016 DC 5.3 with the 8 speed.
Order guide still doesn't tie max tow and the 8 speed together.
(max tow still calls for 3.73's with the 6 speed and 3.42's with the 8 speed)
I chatted online with a GMC rep, and she confirmed that there is currently a mistake on their build website that is showing the LTZ/SLT crew cab standard transmission to be the 6 speed instead of the 8 speed. I guess I just panicked when I saw it on both the GMC and Chevrolet websites.
mine shows a 10/15 sticker on door and it's a DC SLT.. 5.3 8spd.
Also read somewhere all early 2016 SLT's are coming with the Hi-Performance LED headlight option standard... mine shows that option on window sticker as well..
176072af-bbe0-4ea2-a712-1a6f502738d1_zps
This thread got me messing around on the GMC site tonight checking for the options related to the 8 speed transmission. Why is the 8 speed only available with the SLT package? My '14 is an SLE and, aside from an auto dimming mirror, has all of the features I'd want. It seems ridiculous to not make the 8 speed available with the SLE trim.
First it was only 6.2's. Now it's also in 5.3 up trims. Probably will continue to spread as they increase manufacturing capacity.
I guess that makes sense. I do wish it had been available for my '14 but since it will be a long time before I trade out for newer, they'll likely have a 10 speed by then. Heck, the new 2017 Raptor is going to have a 10 speed.
Ford and GM are co-developing the 10 speed. You'll see it on GM's as well.
I'm not sure how the 10 speed will work.
Sounds great and fancy but 8 speed barely did much for gas , just wondering if 10 speed is over kill
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
