New Personalized Tag
LTZTom
I FINALLY got my tag in the mail yesterday. It took forever but it's worth it!!
Sent from my iPhone 6s
That is awesome.... I need to come up with a catchy ome for mine
Sent from my Note 4 on Tapashit
Nice!
I also have personalized plates on all of my vehicles.
And your POINT is??? :P:D:lol::crackup: I crack myself up! LOL
RT
My guess is that his POINT is 2! Lolzlolzlolz
I FINALLY got my tag in the mail yesterday. It took forever but it's worth it!!951b8124c6462486fa2fddbe253dca28.jpg
Here's mine....
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
