Loss of power?
rwilson3944
I have had my 2015 5.3 Sierra for roughly 4 months and other than the horrible shift pattern I love it. But yesterday I almost got t boned turning left across traffic. I pressed the throttle and the truck started to accelerate and then just lost all power for a second or so and then begin to accelerate again and then lost power again. Three times this occurred before normal power and acceleration returned. It's hard to describe almost like the engine is not sending power to the transmission, it didn't matter how much throttle I gave it because by the third time I probably had it depressed more than 3/4 full throttle to get the hell out of the intersection. This has me very concerned because I never know when this will occur again. Any ideas what this may be?
Sounds like traction control kicking in, did you have a yellow light flash at you in the bottom of the speedometer? I've had the same thing happen and it seems a little too aggressive for dry pavement. Putting it in auto if you have 4x4 will give you the best turning acceleration.
Thanks for the reply but it's only 2 wheel drive and the conditions on the road were dry so traction control shouldn't even come in to play. The more I think about it, it seems to be the engine not the transmission I don't recall the engine rpm going up when I was applying the accelerator. Hopefully the ECM recorded something so when I go to the dealer I don't get the "we can't replicate the problem".
Mine did this especially If I was on the power off the power then put the peddle all the way down and it just waited to go.
Same thing as you once I was turning left out of a side road onto a busy highway and the idiot come from the other way rolled the stop sign as in never even really stopped. I had to check up and let him go through the intersection and then I need to go as cars were now coming. Hit the gas and nothing. I turned into the turning lanes to avoid being hit and then of course my truck took off again.
I put the Airaid intake on and my truck has never ever done this not even once with this intake.
If I put the factory air box on to take it in for service it has issues from time to time again.
The one thing I noticed every time the truck would do this I could hear it sucking air. I don't think it was from a lack of air I think it was caused from to much disruption of air and it causes the engine to basically stumble.
So people who defend the factory airbox go right ahead but I will not run it on my truck.
Its a 355hp V8.... You will have traction issued if you mash it off the line.
It sounds to me like traction control kicked in. What TC will do is kind of cut the power going to the wheels until they stop spinning out of sync and then return the power once everything is back in order... All if this in amatyer of a second or 2.
Sent from my Note 4 on Tapashit
ECU wouldn't have recorded anything, they are still pretty stupid at logging data. 2wd on dry pavement flooring it while turning will 100% have traction control kick on.
You have AirRaid MIT or full tube and box/filter?
I do have a K&N CAI on the intake. I really didn't mash the throttle until the third try and only to get out of the intersection. It was a normal turn across traffic it was from a dead stop waiting at a light.I then lightly pressed the gas to start the turn and it moved forward like normal and then lost all power. I also have a GM borla exhaust that's it for mods that may affect the drivability of the truck.
I've got the same issue. I read on another post it possibly could be the torque converter. Haven't had time to go deal with the service dept yet.
  • 4 weeks later...
This happend to me also, I was being abusive. TC off tow haul mode doing a power break and when I let off the break the wheels only spun for a couple second then lost all power. WTF I thought. I just read about Torque Management. Look it up. This will kill injectors when the torque converter senses abuse. It's also the reason for the bogged down feeling when you punch it to pass or something.
Mine would do this on occasion. GM's fuel economy-centric tuning creates a lot of lag when you make sudden throttle position changes. It's almost like the ECU/TCM gets confused on the best course of action when you hit the go pedal.
I got a custom tune. Hasn't happened ever since.
