You guys will be proud.
Today our stupid ass trailer decides to eat the studs on a axle thus we can't pull the trailer back to the shop so we can't take the New Holland back home.  Well me not wanting to have to drive 40 miles one way to get another trailer and get the New Holland I figured I'd save a trip and load the New Holland in the back of the HD.  So I take the tailgate off and back up to a hill. And in my buddy pulls our LX665 Superboom.  Around 5500lbs without counter weights and bucket, which it had both on.  You want to see your truck squat well this puts the hurt on the HD.  Blocked up the inner fenders to keep from absolutely destroying them.  I didn't have a camera or I would post a pic.  Took it to the shop and unloaded it with a 235 and straps I was like ha ain't seeing them fords and Dodges doing that.. :thumb:
The companey i work for has a 30 foot box trailer converted to a tool trailer The trailer weighed 22,050 pounds. It was loaded down to the max. I hauled it from milwaukee WI to KY about 550miles. Had a cummings 1 ton dodge try to pull it he got 50 miles till his wheel bearing's went out.Then put it on a lowboy to haul it to Tucson AZ. All with a 2500HD. It did have some wear on my truck the axle seals are leaking a little. Price to pay for bragging rights.
Chevy Like A rock :eek:
Chevy Like A rock :seeya:
That's awesome man. I love fellow people like myself that push their trucks to their absolute max.  The Mechanical engineers, and civils would be proud of their trucks.  I have bent my tranny cross member bouncing the truck on a drain housing on accident but didn't seem to hurt the truck a hole lot.   Yep bragging rights are what it's all about.  Then you guys wonder why I replace wheel bearings and u joints and misc other parts on my truck.. :eek:
  • 4 weeks later...
Well, let's see -- New Holland construction equipment was bought from Ford Mo. Co. back in the early 90's. So - basically we have a Chevrolet hauling a three ton Ford Motor Company Designed vehicle.
My how twenty years makes a difference.
Wasn't it back in the mid-eighties when ford had the commercial of the F-250 climbing a mountain of rocks with a Chevy sitting across the bed and pulling a goat by the bumper. Guess that was before people spent hours on the internet telling people what a danger to society they are if they exceed the GVWR by 10 pounds.
note: goat = dodge ram, not a bearded billy
Yep remember that commercial. I honestly wasn't doing it to be like check out what the chevy can do in fact at the time I didn't even care if it got hurt. The day was going super s**tty and I just wanted to get home it was late and the bed was calling so I took a chance.
Like we say here in Texas..."it ain't braggin' if it's true!"
Heavy Chevys rule. :fume:
We have a saying kinda like that here.
"Don't let your mouth get you into something your truck can't get you out of"
And I agree Heavy Chevy's kick ass.
I got a good laugh when I pictured a bearded billy tied to the truck :fume:
BDBWTE, in another thread didn't you say GM trucks are too girlie compared to the other manufacturers?.
New Chevy Trucks...what were they thinking
I was concerned only with the 03 Chevy's. It seems to me that the made them sit even lower than previous chevys. Even though I know they are essentially the same truck as my 02 structurally. I just don't like the idea of the truck looking more like a care than a Kenworth.
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
