So it was pretty cold this morning, about -35 degrees Celcius. Truck wasn't plugged in last night, remote started it to let it warm up before getting in. I know that it started and was running for about 15 minutes. It had stopped on its own before I got outside and might had been stopped for 5 minutes. Got in and tried to start it with the key, message popped up saying "reduced engine power" turned the key to start it, it cranked fine but did not start, tried two more times no success. Battery voltage was normal around 14-15V but tried boosting anyways, cranks but still won't start. Decided to try plugging in block heater for 15-20 minutes, tried starting it again (no booster pack) started up just fine but engine light stayed on. Went for a short ride and drove just fine (wouldn't go into V4 because of CEL right). Went back home and cleared the CEL by disconnecting the battery. Drove around for a couple hours with multiple stops and starts, starts fine now.
I find it odd that plugging in the block heater for a short while got the truck to start and was wondering if anyone has had a problem like mine or might know what could cause the no start and reduced engine power message.
Thanks in advance.
Edited by Lilcanadian
Hope mine doesn't do this.... Its only gotten to 20 below F here but mine has started up just fine....
See i bought my truck in Texas.... Texas trucks don't come with block heaters..... Maybe a chiller is needed but i hope i dont ever need to do that.
I have noticed that sometime it takes a bit to start up but that's normal due to the engines being DI.
Sent from my Note 4 on Tapashit
Haha well thanks for your input but hoping that my problem was caused by the extreme cold which probably ain't too common in Texas lol.
In north dakota right now.
It does seem srange that your truck would start normal with the remote start but then refuse to start with the key.
My guess would be mayne the anti theft system had a brain far and you letting it set for 15-20 minutes let it reset?
Yeah that makes sense, odd that it would let it crank though. I've used remote start all winter so far and started it with the key just fine after it shut off many times, you could be right though, I'll have to try and duplicate the problem.
The truck will crank but it won't start if the anti theft is active. My colorado has done that a few times.
Ohh alright thanks for the info, did your check engine light come on after doing this?
Not that i remember but we are talking a 2005 Chevy colorado so maybe the new trucks have changed.
Alright well thanks again
Block heaters are optional everywhere, but I can understand than few Texas dealers would order one.
GM has published a chart of expected crank time vs ambient temperature.
http://sandyblogs.com/techlink/?p=2971
Screen-Shot-2014-02-20-at-11.22.51-AM.pn
  • Like 3
Wow so according to the chart it could've taken about 7 seconds of crank time for it to start this morning I wouldn't even think of letting it crank that long. So I might not had let it crank long enough, then again the truck had been running for 15 minutes so I'm not sure what the coolant temperature would have been when I went out to start it. Might start plugging it in more often, cranking for long periods of time sounds like it could be hard on the starter. Still not sure what the reduced engine power message was for though, maybe due to the low temperature of the fluids?
... So I might not had let it crank long enough, ...
IME, you just turn the key, then let go. It will then crank as long as it needs to.
That's how I usually start the truck, just bump the key and let it turn on its own but it was cranking for a what seemed to be a pretty long time to me and not starting so I would shut it off. This is my first truck with this feature and my first gm so I'm not familiar with this bump the key feature. Will it crank until the starter fails or does it know when to stop?
I would be checking ground connections. check the one that goes to the engine block, a lot of gm trucks will display reduced power when there is a poor ground
I'll have to look into that once the weather warms up a bit, it's even colder today, was -40 when I got up this morning and I don't have a heated garage.
    RyGuy43
    RyGuy43
  • Who's Online   3 Members, 0 Anonymous, 394 Guests (See full list)
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
