Juttering when turning at low speeds
Ezekiel2517
Recently I have been having random "juttering" when I turn sharply at low speeds, mostly in parking lots. It feels and sounds a lot like the slippage grind that happens when you have 4wd enganged on pavement. It does not happen all the time, just 3-4 times now, but I am starting to notice it more.
I keep my 4wd setting on auto. Could it accidentally engaging due to sensed slip? I never get notice of it on my DIC if so. And it seems like it happens quicker than a 4wd shift could occur.
It feels too abrupt and sharp to be tire slippage. I have BFG Rugged Terrains and have not really had a problem with them.
No lifts or any other mods to front suspension.
Any thoughts on what this could be is appreciated. I would take it to the dealer but I know they will just run my tank dry and then tell me they could not recreate the problem.
Thanks!
If the roads are dry or even wet, no real need for AUTO 4x4. I'd put it in 2WD and re-test.
X-2, no need for auto
GM says to use it for variable road conditions, anything else just wastes gas..
If you have been driving your truck in auto all this time, you might want to check the fluid level in transfer case and diff. A change of fluid could not hurt either.
First try tturning auto 4wd off. If it still does it, check to see if you have the auto-locking differential (G80). Mine has locked up at low speeds in town and didn't unlock until I got back on the highway. It makes cornering pretty jittery since the inner tire is turning slower than the outer tire.
Is that normal though? I'm assuming not? I have the G80 and experience the same thing sometimes. Jerks like it's in 4x4 when it hasn't been in 4x4 or Auto for weeks, only when turning as sharp as I can.
Don't know about these newer trucks but back a few years there was a similar problem, it was cured by a special additive to the diff lubricant, seems clutch plates were sticking..might want to check with your dealer and see if that additive is still around.
Interesting. When I bought it, it was in "auto" and I just never touched it. I figured GM did that for a reason. I will try it on 2wd and see if I notice any difference. I dont think what I am feeling is coming form the rear end. I do have the locking rear end (4wd kind pointless without it). I will pay attention next time it happens.
Thanks!!!
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 799 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
