How to remove cigarette lighter socket
Does anyone know how to remove the cigarette lighter socket? I want to remove it to install a switch for my LED bar. I know I've seen it here somewhere but now that i need it i can't find it. I'm not coming up with anything when searching. Thanks in advance
  • 3 years later...
Is there a reason I can not open the link to how to remove and replace the outlets and cover?
On 01/03/2016 at 1:08 AM, TX_AT said:
On 29/02/2016 at 11:17 PM, chuckl1218 said:
Ok, I found the thread I was thinking of...post #15 shows a switch uninstalled in place of the cig lighter outlet and post #25 tells how to remove it...good luck
http://www.gm-trucks.com/forums/topic/173505-obrien19s-2014-double-cab-lt-z71-build/?do=findComment&comment=1633089
Thats exactly the thread I was talking about. Good looking out Chuck. Thanks
I can not open this link I have been trying for a while now. Please help
I installed an airhorn with a relay and really wanted to use this switch because it fits so well in the old cigarette lighter port. Can anyone explain how to use the 3 prong switch with a relay? I used a basic on off switch and it works fine. All the wiring diagrams show one prong for power in, one prong to the accessory being used and then a ground. But wouldn't that defeat the purpose of the relay?
3 pole switches are usually lit.  The constant 12V is for the backlight in the switch.
It's weird because I have it grounded and then the other wire coming off the relay plugged into either of the other 2 poles just lights it up but doesnt do much else. Since its momentary anyways the light really isint important. I ordered a push button switch that will still sit down in that spot and let the cover close. Just annoyed me that it wouldn't work.
The purpose of the relay in your diagram is to convert a negative trigger to a positive output.
If you want to use a 3 prong switch with a positive in, positive out, you would wire the relay - pin86 positive in, pin87 positive output, pin85 ground in, pin30 fused 12volt in
Sorry for the stupid questions, this is my first time wiring anything like this. So the only thing I would be changing according to the diagram on the relay is instead of the weird loop on 86 and 30 86 is another wire running to that 3rd prong on the switch. Damn wasnt looking forward to running another wire through the firewall. Ordered a plain black 2 pole switch to see of it would fit in the charging port I opened up. I really dont need the light. I appreciate the help.
Is your relay in the engine bay? If it is, wire the 2 pole switch with accessory/ignition in and out. Accessory/ignition out to relay pin 86, then pin 87 to light bar 12v. Pin 30 and 85 will go to battery.
Did you run 2 wires from the console switch to the engine compartment?
Relay is under the hood, and I only fished one wire into the cabin. I wired it just like the diagram with a cheap toggle 2 pin switch and it works fine, my better 2 pin switch comes today if it doesnt fit right I'll try to wire that 3 prong to the relay and fish another wire through.
You won't have to fish another wire through with the 3 prong. There's a fuse that can turn your sockets to ignition power. Take that and feed your 3 prong switch, then use the single wire to the relay in the engine compartment
    • And to top it off finally.......................these small GM LS engines are designed to SPIN!!!!!  Why choke them down to just off idle for cruising.  Why/how the "bean counters" have influenced the "engineering department" at GM is beyond me.   They took a solid platform of an engine and turned into a joke in OEM form!!!
    • Atlas,   Then following your logic we can't believe any story that the MSM produces? I mean it's documented they heavily donate to Democrat candidates. Vote Democrat in high percentages. Many MSM talents are married to Democrat politicians, Gov. employees. That goes for on-air and off, personalities and reporters. So they would all be biased and nothing they produce is to be believed in your mind?   Again the article simply was about ways AI can be used for pricing products. Nothing discounted current situations as a factor.    Again keep looking through your left/right lenses. I don't live my life that way.   And as a heads up this thread will be cleaned up again as much of this is off topic and is receiving
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
