I only have the issue at one station. The fix there was to hold the handle sideways with the hose pointing towards the rear tire. Frustrating until I figured out this trick.
I fixed mine today check your vent hose that runs from the filler neck to the tank and see if it has a kink in it. If it does that's the problem, I cut 2" off of the hose and straightened it and reinstalled and that fixed it I put 24 gallons of fuel in about 2-3 min. Fixed!!
RT
I got my truck back from the dealer for this issues and the paperwork/ the service writer stated that their was a debris stuck inside the hose I guess causing the issue. I don't believe that but as long as the tech fixed the issue is all I care. Pumped gas and no issues yet.
  • 5 weeks later...
Keep us posted. Post an update in about a month or so.
It has improved but it still happens but not a lot before the tech did what they did. I went back for the driver seat moving around, they shimmed it or something and also complained about the gas tank issue. My service writer stated they are going to replace the gas tank so it's on order right now. They will call me when the part comes in and replaced the gas tank from what he explained to me.
Check the vent hose for a kink in it...It won't take much to disrupt the air flow to vent the tank properly. Not sure why the dealers are relpacing the fuel tank.
RT
Yes make sure to check the hose changing the tank won't fix the problem or atleast it didn't with mine. Theye "removed the tank and blew all the vent hoses out. Problem solved.
Dropped of my truck today, I check with the service writer and he stated yes they are replacing the gas tank. I wish I knew more details what's wrong with the gas tank but the tech is installing a new gas tank for sure. Coming from the service writer.
With mine, if I put the nozzle all the way in, it would shutoff every $1.50-$2.00, on most pumps. I have been dealing with it, just have to remember to put it all the way in and pull it back out about 1/2".
I know if I hit a freak gas station with real good pump pressure these trucks do not like it.
I have to slow it down a bit.
I did have one issue with my 2014 once it kept shutting off so I assumed it was full and when I got back in it was at half.
Went to a different station and it filled right up. I just assumed the pump I was at had an issue and was kicking off to easy.
It only ever happened the one time. I was back at the same station using the same pump with no issues but I have no idea they may have fixed the pump.
  • 10 months later...
Not sure if I updated but my dealership replaced my fuel tank last tear and fixed all my issues. No more pump trigger going off now
    250.6k
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 699 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
