I brought my new 16 SIerra into the dealer yesterday to take care of a few rattles. One in the upper dash around the windshield and another that seemed to be under or behind the steering column or gauges. They called me a few hours later and said both were fixed under an existing bulletin. They added insulation to under the trim piece along the dash where it meets the windshield and the same bulletin called for insulation against an inverter under the steering column area. I don't have the bulletin number with me right now.
I haven't heard the rattle under the steering column again yet but the dash one is still there - sounds different now but still there so I plan to take it back next week.
Anyone else have experience with these rattles?
I have a 15 Sierra sle, and it started making a rattling noise up by the left dash speaker. I have not taken it in yet as I'm afraid they will mess with it and make it worse. Prob have them look at it next oil change.
order some felt tape on amazon, and apply to the edges on your dash (the long piece that sits against the windshield and speaker covers), you'll have to remove the a pillar covers to get it out, but $12 and 35 minutes I was done. I'll try to find the pics on my phone.
I have this sound that sounds like a small rock chip hitting my windshield up where the dash and windshield meet occassionally. Like a lil cracking sound. I check my windshield every time and theres no actual crack.
(no its not actual rock chips hitting the windshield)
Ever find those pics?
Used tape like this? http://www.amazon.com/Yosoo-Universal-Flannel-Squeak-Adhesive/dp/B0169U1X7I/ref=sr_1_1?ie=UTF8&qid=1458302933&sr=8-1&keywords=automotive+felt+tape
10636779_10102644925096004_1999360128160
The small thin black is from the factory felt, the wider loooong strips are mine
12362805_10102644925091014_1391689140942
12371017_10102644925100994_5224628396311
Sorry it too so long, I had to search Facebook for them as I deleted them from my phone. I'm doing this from a work computer which is a no no, so I'll post link of tape later. Hope this helps
Thanks.
is that tape in the circled area too? are those tabs that insert into something? i haven't taken that piece off to investigate yet.
what about those metal clips i pointed to? those are the source of squeaking?
Was your rattle when just driving or due to the bass from the radio? I have a rattle due to the bass and it seems to be on the passenger side. I was trying to determine if these pictures might apply to my situation. I've had the rattle since day one of ownership and just can't deal with it anymore.
That sounds more like a bad or loose speaker. I would take it in. The dash speakers are supposed to be high passed so could it be coming from the door?
Edited by crewl1
I think mine is the plastic piece up by windshield. If I hold it it stops.
Thanks.
yes i wrapped the tabs, but used a screwdriver to open the clips. no more rattles.
To the guy asking about radios- it rattled regardless of radio operation.
Mine does the same thing, it drives me and my wife crazy. i cant seem to find the source, but it rattles when music is playing.
Another culprit is the daylight sensor (little half circle shaped that hooks up to the same piece)
Add some padding between that and the socket it goes in, good luck!
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
