How-To: Adding A Coolant Filter K2.
  • 1 month later...
  • Replies 38
I like this idea also. How is the working out for you guys that have done this? This does not take the place of regular coolant changes but should help to keep the system clean.
Did the original poster put a T in the line? I cannot see this being a benefit. Since the filter is a restriction in the flow, the flow is all going to be through the T. I think you should probably rethink that. I understand that you do not want flow to stop completely because the filter gets clogged, but adding the bypass like that essentially eliminates the purpose of the filter.
I'm at 57k now. Working great. Coolant is clean. As long as the filter doesn't get ridiculously clogged flow will not be impeded. I'm at 60k and have no intentions of doing a coolant flush. I'm following the owner's manual and checking flow through my filter at every oil change. I think 30k -45k might be a good interval for the coolant filter. The filter is very large, especially for a small gasoline passenger car engine. I'll probably change mine around 75k, IIRC believe I installed around 42k or 44k. I also check the antifreeze freezing level at every oil change and check for coolant electrolysis with every bell and whistle turned on and during startup. I must admit, I'm curious how much debris is inside my filter. All I know is my overflow is clean as a whistle now.
Thanks for the reply FL355i. The way you had yours setup with out a T is the way it should be done IMO. Glad to hear this is working good. I may need to do this. I checked mine to see how you have yours setup and it looks to be pretty easily done. Thanks for all the detail.
No worries. I also agree there is no need for the tee. There are other hoses and passages to relieve pressure in the even the filter is plugged. Heater hoses, radiator hoses... again, this filter is massive and could honestly probably go 100k w/out plugging but I rather not find out. The 1st filter probably catches 99% of the debris from the manufacturing process. The 2nd filter could probably go the life of the truck in all honesty being a gas motor. But I'll stick with a 30k on the 1st filter interval and then 45k intervals on the 2nd filter on. Following the owner's manual for coolant flushes along with checking for electrolysis and freeze protection on top of the filter is beyond good. The coolant will not be the downfall of the truck. Frame will probably rust out before the coolant system goes bad.
Reminder, I removed my valves. I was not happy with the china quality and did not see a point for them. When replacing one of the hoses I lost only ounces of coolant. Valves would be needed if the filter is mounted low on a semi truck and you have a big issue on your hands just to change the filter. Valves were a complete waste of money. And the Autozone hose is crap quality. It's rock hard. The NAPA hose is still good.... So i'm replacing the autozone hose with a Napa hose soon.
  • 7 months later...
I'm at 68,500 miles now. On the 2nd filter. Coolant tank is clean. No issues at all other than the top of the filters rust pretty easily and look bad. Un-painted surface on the filter. Aside from that it's great.
  • 3 months later...
Just added these parts to my Christmas list. We'll see if this shows up. It will give me something maintenance wise to do over the holidays while I am off.
Still doing good for you?
  • 4 months later...
Check out this link, I just did this as a quick and cheaper alternative. Will replace the filter much more often, but again it's still cheap and very easy.
I'm just curious what your opinion is on this; do you see any problems with this, or am I good. Thanks.
http://www.gm-trucks.com/forums/topic/210771-interesting-coolant-filter-find/
Good read.  Looks like the paper element of the fuel filter was coming apart on him.  The alternative is to run a bronze sintered type fuel filter.  After my "extensive" coolant flush and overflow bottle replacement I removed my coolant filter setup.  The cast iron base was starting to rust, inside where the filter attached, in contact with coolant.  The same setup is still on my '89 K5 with Green coolant; no corrosion on the filter housing of any kind. So I am not running anything now on the Silverado, just the K5. After the flush and removal of the big filter setup, I ran an inline fuel filter, sintered type for about two weeks in the overflow hose.  Was clean as a whistle.  I removed the filter and put the OEM barb fitting back in.
I bought something similar to these, cheaper, to run for 2 weeks after the flush and fill.
https://www.speedwaymotors.com/Earls-AT230103ERL-Fuel-Filter-Sintered-Bronze-Element-5-16-3-8,272675.html
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
