Turn off headlights while driving in the day time?
Wondering if it's possible to just have your marker lights on in the day time and not your headlights. I see other trucks that just have their marker lights on. (Dodge, Toyotas, Fords). Any info is great!
You can, but you'll have to turn the headlight switch manually to the marker lights.
I have done this and it seems that the headlights stay on still until I put it into park then they go off.....
That doesn't work either as soon as I shift out of park headlights come on...
Are you in Canada?
Are you in Canada?
Yup
Yup
I might be wrong but I think for Canadian trucks it's programmed that way in the ECM. I don't think it's possible. There's a topic called "Disabling DRL" and it was discovered your trucks are done different than the US.
Canadian trucks can't easily disable the DRL. Different brands use different lights for DRLs.
I believe MikeNH and JRL1164 are correct. If I recall correctly it has to do with Canadian Laws and the whole DRL thing back in the... late 90's? when it was being passed. Some (but not all) provinces require Daytime running lights be active (must be on if in motion) on vehicles past a certain year of manufacture. Only reason I remember this is back when I had my Avalanche and was involved with all that the question came up about how to disable it and they couldn't back then as it was embedded in the BCM or something. I am not from Canada, would be interesting to find out though just for accuracy and curiosity which provinces have that code/law if that indeed is the case.
Ya i figured it had to do with Canadian Laws. You are correct most if not all provinces require daytime running lights but i just thought there may be a way to make the "marker" lights the DRL. I see lots of new trucks like this around and surely they are not all from the USA. But like one of the other guys said different manufacturers are using different DRL.
I am sure you can, if you flip which cables go to which lights and get the proper adapters/connectors if necessary. After that observe proper voltages and polarities, etc. Hopefully, someone whom has played with the lighting wiring on the front end will chime in. I haven't had time to add my hidden grill light bar yet due to work and other stuff going on.
Daytime running lights make you more visible on the road. Marker lights make you visible and headlights even more. Re-configuring your DRL's may be possible but maybe not an improvement. Last night I was driving my motorcycle on the highway with the sun in my eyes and it is surprising how much more visible the oncoming cars are with their headlights glowing. As a driver I know I can't depend upon people having their headlights turned on, but I want to be as visible as I can to those who may have trouble seeing me. If you can't find a solution to your wiring question, it may not be a bad thing!
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
