New graphics cards announced
So anyone excited about the new 1080 and 1070 announcements from the other day? So many console gamers on here probably not lol. If AMD can't step it up with their soon to be announced generation of cpus and gpus I think they'll be pretty screwed, especially if Nvidia's claims hold up with independent testing. It's going to be an interesting year for the "master race." :-p
Knew I forgot something. There are probably hundreds of articles, I know I've watched most of my tech youtube peoples talk about it or show the huge announce party thing Nvidia did. After watching the release videos I'd be shocked if the total for all that was anywhere as low as $1 million. Flew in tons of people, rented out a ranch, activities, hotel rooms, and all for what I'm guessing is more money than I'll see in my lifetime lol.
http://www.anandtech.com/show/10304/nvidia-announces-the-geforce-gtx-1080-1070
http://www.theverge.com/circuitbreaker/2016/5/7/11615806/nvidia-gtx-1080-1070-pascal-specs-price-release-date
I only see smaller micron.. gain some cool.
the cards have been so fast since agp 8x, that is all to notice.
cooling makes it bigger.
256bit memory, all that hocus pocus... must be 10 years already.
I got a xeon with the original nvidia, big 3d cad worker, but no gaming.
I'd love try try the 980..
but no rush.
my first gamer was 8mb rage lt pro. Half life 1 for daaaays. :)
I don't even know what the first graphics card I used was. I know it was back when we still had a 486 and a 386. Dad said he needed to get a card just to run the 17" monitor. 8mb hard drive ooooooooo yeah! Or maybe it was 8 megs of ram, that sounds a little better. I don't know this was 20 something years ago :(
I do, mine was a 3dfx voodoo 3 card. Before nvidia dominated the scene 3dfx was the card to buy if you wanted performance and dependability back in those early days of PC gaming.
I think the first card I bought with my own money might have been a Geforce 2 Ti that I got off my buddy. Most expensive card is what I currently have, my 7950 bought launch week.
I heard about it, I'm excited because it'll make the lesser units cheaper.
Sent from my SM-G920V using Tapatalk
If the performance of the 1070 is anywhere near what the claims are I'll probably just get that. Not that it matters pretty much any mid grade card now beats my current one so I step up regardless.
Looks like them embargo is over today so a bunch of videos are out/coming out.
and dispelling the incorrect info about 3 and 4 way SLI. Not that I would ever do it, even if I could.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
