Ive tried asking this question in a other threads, but this in its self is the root question.
Are there any aftermarket Camber adjustments products out there for the 2014-2016?
I called all the Upper control arm companies, Cognito, Zone, ect... None of them would say they added any camber help with there upper control arms.
So my problem is I have a 6.5" lift then I added Bilstien 5100 set at 1.25". So now my Camber is maxed out in its adjustment yet im still 1 Degree Positive still. I need something to help me get my camber near zeroed out or even a bit negative.
If you go to the next lower setting on the Bilstein, would that make a difference?
So you stacked a lift kit with a bilstein lift? No wonder you have no camber left. That's not how those are supposed to be run...
I dont go with the norm. Its not a big deal to stack a lift. People do it all the time. I did the same thing on my Tacoma With a spindle lift and Bilstiens. The tacoma aftermarket made a adjustable upper control are that would add or subtract camber. The Problem is that there is no aftermarket camber product for these trucks that I can find or know of.
What's holding you back from more adjustment the keeper or does it start going back positive ?
I guess it the keeper. The pin is maxed out in one direction.
Did you call Dirt King and ask about their UCAs? (619) 944-8913
No I havent tried them. I will in the morning. Thanks.
Cut the keeper in a way so that the pin want stop it so you can get more adjustment but make sure the a arm is not hitting the frame afterwards but it also might start going back positive just have to try it and see
  • 6 years later...
moog makes a adjustable upper with 3 degrees of adjustment. part#s are RK100214 AND RK100215. They re not cheap but will solve your problem!
