Ive tried asking this question in a other threads, but this in its self is the root question.
Are there any aftermarket Camber adjustments products out there for the 2014-2016?
I called all the Upper control arm companies, Cognito, Zone, ect... None of them would say they added any camber help with there upper control arms.
So my problem is I have a 6.5" lift then I added Bilstien 5100 set at 1.25". So now my Camber is maxed out in its adjustment yet im still 1 Degree Positive still. I need something to help me get my camber near zeroed out or even a bit negative.
If you go to the next lower setting on the Bilstein, would that make a difference?
So you stacked a lift kit with a bilstein lift? No wonder you have no camber left. That's not how those are supposed to be run...
I dont go with the norm. Its not a big deal to stack a lift. People do it all the time. I did the same thing on my Tacoma With a spindle lift and Bilstiens. The tacoma aftermarket made a adjustable upper control are that would add or subtract camber. The Problem is that there is no aftermarket camber product for these trucks that I can find or know of.
What's holding you back from more adjustment the keeper or does it start going back positive ?
I guess it the keeper. The pin is maxed out in one direction.
Did you call Dirt King and ask about their UCAs? (619) 944-8913
No I havent tried them. I will in the morning. Thanks.
Cut the keeper in a way so that the pin want stop it so you can get more adjustment but make sure the a arm is not hitting the frame afterwards but it also might start going back positive just have to try it and see
  • 6 years later...
moog makes a adjustable upper with 3 degrees of adjustment. part#s are RK100214 AND RK100215. They re not cheap but will solve your problem!
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
