They did a full evacuation and refill. All systems checked out (according to them). 1.7lbs of refrigerant was put back in. I interpreted it as "max" cold. I do understand what you're saying though. Are there any techs on here that can tell us what the information I posted means?
I called another dealership, their tech was nice enough to look up the specifications on the A/C system for my truck. He went through the tech specs and agreed that the maximum cold temperature that comes out of the vent is 50degrees. Nothing colder.
This makes me wonder if it's possible through HP Tuners or EFI Live to make any changes to the PCM or BCM that would allow for colder operation. (I.E. higher fan speeds, compressor duty cycle, etc).
Needless to say, I'm not happy :(
Here lately it's been 85-90 F out. The temp gauge stuck in my vent will read 42-44 F after a few minutes of cooling down and on low fan. Starts off around 50'ish when I first turn it on and on high fan.
Sent from my SM-T817V using Tapatalk
Not sure out here in Phoenix the AC is on every month other than a couple winter months......I think you would die without AC!
I thought this too, then I realized my temperature perception was just skewed and I had the settings too high for what I was looking for. Turn the dial down to 63 and that bitch will get ice cold, atleast mine did!
Mine seems to run around 40-43F. Thats what it ran this last weekend driving down the interstate with air temps 88-91F. It sucks to have a vehicle that the AC never really works great.
Had one,couldn't deal with it, traded it.
  • 4 years later...
You folks do realize that if your vents are producing say 50 degrees, That means your evaporator temp is in the neighborhood of 40 degrees. 8 degrees colder and you'll will start freezing condensate on the coil. Once the ice or frost build up you really start loosing cooling. If you get 45 or below consider yourself fortunate. As the coil gets colder the refrigerant pressure gets lower. The low pressure switch cuts off the compressor to prevent freezing the coil. Run you fan on the lowest speed. That will give the evap enough time to cool each molecule of air passing thru it. Yes I know the old days of the A^ compressor and giant evaps and condensers put out fog. We are dealing with smaller fans,coils and refrigerant capacities nowadays
Hi guys, I have a 2015 Silverado W/T that has less than 2000 miles on it. I do a lot of short trips 10-20 miles at a time and the A/C has never been what I call COLD. But rather it's just cool and never gets cold enough that it's uncomfortable. My old 2004 Silverado is another story. That truck can blow some seriously cold air!
Today I did some testing. I had a 15 mile drive home from work and I brought along my old trusty thermometer. It was 79 degrees and humid out so I decided to use the air. All the colder I could the vents was around 48-49 degrees. This was mixed driving with both highway (55mph) and idling in traffic.
What are you guys seeing for temperature in your trucks coming out of the vents? Is this temperature normal now for these new trucks? Do you think mine might be a hair low on refrigerant?
If this is normal, I guess I can accept it. I was just hoping it would be about 10-12 degrees colder to be like my 2004 Silverado.
Any information, thoughts or observations would be greatly appreciated.
For the record, this afternoon I took my wife's 2008 impala out in the same weather and I was pulling temps around 42 degrees with the same thermometer placed in the center vent.
Have you checked the temperature of your passenger vents?? If you notice a major difference, it's probably the well known door blend issue.
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
