So I looked threw several hundred posts and didn't see anything so here it is. When I switch my drive electors between modes I get a audible high pitch electric type noise. Not a big deal but I notice it frequently does it in the auto mode. This is definitely annoying enough to keep me out of this setting which I prefer to use when roads are wet. Has anyone else had this problem and where they able to get it fixed. My truck is 2016 Sierra Z71 with a little over 1k on it. Much thanks
Normal.
#PIP5261A: Faint High Pitched Whine Noise In Auto 4 Wheel Drive - (Feb 8, 2016)
Subject: Faint High Pitched Whine Noise In Auto 4 Wheel Drive
Models: 2014-2016 Chevrolet Silverado 2014-2016 GMC Sierra 2015-2016 Chevrolet Suburban Tahoe 2015-2016 GMC Yukon, Yukon XL, Yukon Denali 2015-2016 Cadillac Escalade, Escalade ESV Equipped with Automatic Transmission and 4 wd RPO NQH or NP0
This PI was superseded to update Model Years. Please discard PIP5261
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment on a high pitched whine noise from the vehicle noticed when driving in auto 4wd. The customer may comment that it is an intermittent noise and no noticeable pattern to when it can be heard.
Recommendation/Instructions
The transfer case control module on these vehicles is located next to the accelerator pedal and is not covered by any close out or hush panels.
When the transfer case control module has to move the transfer case actuator motor the higher current passing through the module causes an "electronic buzz or whine" within some of the capacitors in the module that can be heard by some of our customers.
Typically this can only be heard with all accessories and HVAC off and only when actuator movement is required. This does not indicate a concern with the module and should not be replaced to address this concern.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
My 15 HD does it when you shift positions, my 2012 did it when you shift and when in AUTO like the new ones do.
Edited by 15HDriver
Good morning JASLAR12002,
I regret to hear you are experiencing this high pitched noise in your Sierra. While I recognize that you reaching out to other forum members for advice, I would like to offer additional assistance if you wish to work with your dealership. Send me a private message with your VIN full contact information, current mileage and preferred dealership if this is something that interests you.
Best,
Julianne M.
GM Customer Care
So just an update!!! I took it to my dealer and they said that there is nothing that they could do for the issue. On the 2016 there is a higher frequency running threw the shift dial and it is a known problem. Said it can be resolved with som me dyno mat to trying to insulate the sound but they could not do this in house saying it will void warranty. They have had several complaints about it be Gm has yet to release anything official or come up with a correction at this time.
This is more than a year old. but it likely still applies:
http://sandyblogs.com/techlink/?p=4314
High-Pitched Sound in Auto 4WD
February 20, 2015
A high-pitched whine sound may be noticed when driving some 2014-2015 Silverado, Sierra; 2015 Suburban, Tahoe, Yukon models and Escalade models in Auto 4WD (RPO NQH or NP0). The sound is intermittent with no noticeable pattern.
The Transfer Case Control Module (TCCM) on these vehicles is located next to the accelerator pedal and is not covered by any close-out or hush panels. (Fig. 18) When the TCCM has to move the transfer case actuator motor, the higher current passing through the module causes an electronic buzz or whine within some of the capacitors in the module. Typically, this sound can be heard only with all accessories and the climate controls off and only when actuator movement is required.
The high-pitched whine sound does not indicate a concern with the module and should not be replaced to address this condition.
This is the price we pay for being too lazy to use a manual transfer case lever.
This is the price we pay for lazy/cheap engineering. There are capacitors designed specifically to fix this problem, but since they are a few cents more GM will not use them. They lift the capacitors off of the circuit board slightly so the noise is not generated.
  • 4 months later...
I don't know what to do, I just started snowing in Minnesota and I can't use auto or 4 wheel drive because the high pitch noise literally makes my skin crawl. How can't Gm do something about this? I have a 2015 sierra Denali and love it but might have to trade it in if this can't be fixed. It's like nails on a chalk board
It shouldn't be continuous.
I love how when you ask the dealership about this issue, they stare at you like you are crazy and hearing things. I wish I knew something that could fix it and yes it's continuous when I'm in anything but 2 wheel drive. It drives me nuts. We got 6 inches of snow today
  • 3 years later...
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
