2016 Double Cab Midnight Edition
Well the wait was worth it. I picked up my new DC Midnight Edition.
It's finally nice to buy a truck and not have to blow it up to make it what i want.
Fully loaded and lovin' it so far..
13502061_1187365461283505_33174109296685
Do you have any more pictures of your truck. I been searching for a identical truck and finding no luck, I been debateing on ordering one.
Good looking truck! I like the wheel swap also.
The turn signals are orange though? I guess that would be the only difference between the double and crew? Or is that an LTZ thing?
Much better!
I wanted to break up the black a little bit and I had no use for those off road wheels and tires.
GM 22's w/Toyo Proxies S/T's
The dog does not completely match? May have to get some mods for him to. :P
Not a double or crew or LTZ thing. It must be a Midnight Edition thing. My 2016 double LTZ with white turns:
Pretty sure it is an LTZ thing. My midnight edition is a crew cab LTZ z71 and has the Clear LED turn signals instead of the yellow covers with bulbs.
Nice truck. Have the same Toyo tire on mine for summer. Good tire at a good price!
Lasted one week before I traded it in. I settled on the 5.3 to pull my trailer, although it did a significant job, I wanted a 6.2 and drove 500 miles to go get one. Lost about three grand but I'm real happy with the new one.
Wow Traded it already,I did something similar as a trade in.I bought a used 2014 took it to the dealer a 10 days later to have a new tailgate put on promised by dealer couple days later they called told me it had a seat belt recall and wouldn't let me take the truck till it was fixed(safety).The parts were on back order they said I can drive a new truck till fixed well I bought a 2016 to be done with it.
That's also a nice truck did you keep your rims(22")?
Congrats Again!
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,555 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
