Driver Information Center - accurate?
I agree, you need to check mileage over multiple fills.
And just to clarify, by gauge, I meant tire pressure gauge, not fuel gauge.
On my 2007 Sierra, the DIC was approx 5% "optimistic" on mpg reporting when compared with hand calcs and actual gallons filled. Interestingly, the "Gallons Used" (which was available in the '07 DIC, and apparently not in the 2016 DIC of my new Sierra) was 5% optimistic. Unless I am missing it, there is no screen that any longer provides gallons consumed.
I concluded that the "bias" in mpg reported was due to the inaccuracy of the "fuel consumed" measurement of the vehicle computer. Odometers are extremely accurate anymore, and have been for a long time.
The 5% optimistic number was an average deviation of fill-ups over a period of 9 years, i.e. literally hundreds of fill-ups (I just entered my fuel receipt in an automated spreadsheet and let it do its thing). Sometimes it was dead nuts, other times (especially in winter for some reason) it could be waaaaay off.
I also came to the conclusion on the '07, that the fuel used reported by that '07 DIC apparently was NOT measuring if you performed a remote start, and began measuring when the ignition key was inserted and turned to the run condition. This conclusion was drawn after numerous informal surveillance tests.
WHy, might you ask, did I give a c___? Well, when i was into tuning, injector pulses go into the long term and short term fuel trim adjustments of the ECU, and therefore I had a need at the time to do some snooping. I am an engineer by profession and do get intruiged with stuff like this (pity me, I know).
On my 2016 SIerra, I only have one fill up thus far, so I can't draw any conclusions yet. After a few months, I can post my results.
Not counting fuel consumed before the key's inserted on remote start? That's nuts. I hope that's been fixed.
In any case, I'm only on my third fill up but I haven't been keeping track of anything. Maybe I'll start on my next fill.
If you want to compare dic and hand calc, then check every fill up 10 or more times in a row. This will help to average out any differences in fuel level when the tank was filled.
dic doesn't know (or care) how much fuel was added, it just measures the flow through the injectors.
(the fuel gauge is NOT what the dic uses to calculate fuel mileage)
Been comparing it for the last 6 months. Mine is ALWAYS 1.0 MPG higher than by manual. The truck is a bone-stock '14 Sierra CC 4x4 3.08 gear w/ 18" Goodyear FuelMax tires. I rarely use the remote start (but I have been this week since it's 101 here).
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
