Well first off I'm having an issue bought motor mounts turns out original motor mounts are offset from each other now the question is do I use OEM Frame brackets to a small block 350 truck originally had it straight six.
I would call a place that does ls swap
There is a place in Houston that does it
I'm sure they could led you in the right direction, I hope to do a ls swap in the future
Sent from my SAMSUNG-SM-G870A using Tapatalk
Holley and hooker make swap kits that come with mounts
yes they do i have hooker mounts from summit racing. The driver side stock mount bracket sites 2" further back than the driver side.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 376 Guests (See full list)
