If my 2004 suburban blows the 10amp A/C fuse, is there anything to check besides the clutch itself being shot? The 4 prong relay next to the fuse is good. The snowflake on the dash controller is on. I couldn't find any bad, shorted, or cracked wires leading to the compressor clutch. I heard some vehicles have a diode on the wire to the compressor clutch. Does a 2004 Suburban have a diode?
No it doesn't. You can unplug any one of: high side connector, low side connector, or compressor connector, and it wont blow fuse. I've kind of decided its the clutch magnet.
Yeah, that's what it sounds like. Common failure for a coil of wire. It can easily short to ground with age.
  • 3 years later...
I doubt you'll see this...but just out of hope, did you ever figure out what it was? Same exact issue on my '04 Burb, replaced AC clutch and still has the same issue.
  • 3 years later...
23 hours ago, Chopper steve said:
I have a 2005 Chevy suburban 2 Wheel Dr. It keeps blowing the AC fuse.
We regret to hear of this HVAC concern you have been experiencing with your Suburban and would like to take the time to learn more. When you have a moment, please send us an email to [email protected]. Make sure to include your Username and Forum name in the subject line with additional details. We will await your email.
  • 9 months later...
2004 5.3 AC fuse kept blowing when driving then found out only when I turned the wheel...  The harness runs next the steering linkage and rubbed through the insulation ground out on the knuckle as it turned...  electric tape and a zip tie to get it away from steering linkage fix it
    daveishi
    daveishi
  • Who's Online   4 Members, 0 Anonymous, 356 Guests (See full list)
