Anyone had their transmission replaced under GM Program# 2044120? Talked to dealer about this today and GM is not replacing parts but the whole transmission. I set up an appointment and asked if mine really needed it as it seems to not have any issues. Of course they said I should and would take a couple of days. Suppose to drop off Monday morning.
did you receive a recall notice or take the truck in for service under warranty?
This is nothing new, been policy since the 8-sp was introduced. Dealers are not to open them up for repairs.
I have a 2015 denali w. the 8 speed and it has already had a new torque converter. Now i still have the delayed engagement upon start up. They issued this #16-NA-014, which states they will install a new stator shaft?? This is the issue I have now. I wasn't' crazy about them opening my trans. Are you sure and saying they will not open it up just replace it???? Is there a TSB or something written.
Thanks
Edited by seamus2154
They sure do... just had the stator tsb done and they took it all apart and put it back together again. I even have the work order to prove it lol.
Sent from my SM-G900W8 using Tapatalk
Edited by 1994Vmax
The transmission is currently on exchange through the GM Product Quality Center (PQC). No transmission repairs, internal or external, are allowed at this time. If diagnosis has determined the need for any repair to the transmission, contact the PQC to discuss the information/diagnostics that led to the need to repair the transmission assembly before performing any repairs.
Edited by elcamino
That's nice... also totally out of date and completely irrelevant.... research the stator tsb... yes dealers dismantle the transmission.. end of story.
Edited by 1994Vmax
I have to wonder with all the searching, jerking, hesitating and jerking again what the hell its doing to my drivetrain life cycle.
Nothing in the mail. Checked for recall with my Chevrolet app and popped up. GM program #2044120 date issued Jun 21,2016.
Program title: Cracked 2-3-4-6-8 Clutch Piston
Program description: Certain 2016 model year Cadillac CT6, Chevrolet Silverado LD and GMC Sierra LD vehicles, equipped with an 8-speed automatic transmission, may have a condition in which the 2-3-4-6-8 Clutch Piston is out of specification. Parts exhibited a crack condition as cast after machining. As a result the vehicle could exhibit 1-2 up shift slipping ot a flaring condition.
Safety Risk Description: The Vehicle could exhibit 1-2 up shift slipping or a flaring condition.
Repair Description: Replace the transmission.
This is all I have information wise. Dealer confirmed I would get a entirely brand new transmission. I'll keep you all posted.
Is there anyway we can confirm that we are eligible for this recall of the transmission?
Thanks
I still have the delayed engagement when I start my vehicle and put from park to drive.
Edited by ChevyRoofer
    • I would like to know if I can increase my 2025 Silverado 2500 HD
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
